Second subdomain receive the certificate for first subdomain
Hello everyone, I have a problem with two subdomains with the same IP.
When i execute: sudo certbot certonly -d demo.xxx.yyy, all goes clear and i recive the certificate, but when i put this certificate on production, the browser say this is for secure.xxx.yyy (the second subdomain that i controll)
The SNI option it’s activated and configured.
Hi @roldan
please share your domain names and your configuration files.
My domain is: secure.ctech.financial and demo.ctech.financial
I ran this command: sudo certbot --authenticator webroot --installer nginx -d demo.xxx.xxx
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t close to expiry.
(ref: /etc/letsencrypt/renewal/demo.xxx.xxx.conf)
What would you like to do?
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
http-01 challenge for demo.xxx.xxx
Select the webroot for demo.xxx.xxx:
1: Enter a new webroot
Press 1 [enter] to confirm the selection (press ‘c’ to cancel):
** Invalid input **
Press 1 [enter] to confirm the selection (press ‘c’ to cancel): 1
Input the webroot for demo.ctech.financial: (Enter ‘c’ to cancel):/www/demo
Waiting for verification…
Generating key (2048 bits): /etc/letsencrypt/keys/0000_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0000_csr-certbot.pem
Cannot find a VirtualHost matching domain demo.xxx.xxx.
  • Unable to install the certificate
  • Congratulations! Your certificate and chain have been saved at
    /etc/letsencrypt/live/demo.xxx.xxx/fullchain.pem. Your cert
    will expire on 2018-11-12. To obtain a new or tweaked version of
    this certificate in the future, simply run certbot again with the
    “certonly” option. To non-interactively renew all of your
    certificates, run “certbot renew”
My web server is (include version): nginx/1.10.3
The operating system my web server runs on is (include version): debian 9.4.0
After that, did you manually install the certificate into nginx? Does nginx have a demo.ctech.financial virtualhost set up?
Yes, i install manually the certificate into nginx
and Yes, the have demo.ctech.financial virtual host configured
Can you show us?
Solved, there is a problem with the DNS Provider.
Thanks a lot for que quick response.
