SeaFile Certificate for https but get connection refused
gonsernas.zapto.org
sudo certbot --authenticator standalone --installer nginx -d gonsernas.zapto.org --pre-hook "service nginx stop" --post-hook "service nginx start"
Plugins selected: Authenticator standalone, Installer nginx
Running pre-hook command: service nginx stop
http-01 challenge for gonsernas.zapto.org
Running post-hook command: service nginx start
Failed authorization procedure. gonsernas.zapto.org (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://gonsernas.zapto.org/.well-known/acme-challenge/3N6nKsSq-YYNU7Vo0QRBpDkpkOK5Ti7c_OGVee_dANk: Connection refused
    Domain: gonsernas.zapto.org
    Type: connection
    Detail: Fetching
    Connection refused
Raspberry Pi 3b
Kabel-Deutschland
i think no
python-certbot-nginx is already the newest version (0.31.0-1).
Hi and welcome to the community!
Is port 80 open to your system?
Have you confirmed the IP?
Show:
curl -4 ifconfig.co
[&2* readers: Get involved; Be heard. It starts with: if you read something you like, then like it :heart:]
Yes it is open. Http Port 80 for my GonserNAS(RaspberryPi)
This comes out: 77.21.252.87
And yet:
curl -Iki http://gonsernas.zapto.org
curl: (7) Failed to connect to gonsernas.zapto.org port 80: Connection refused
curl -Iki http://77.21.252.87
curl: (7) Failed to connect to 77.21.252.87 port 80: Connection refused
Is there a router/modem that would need to be set to port forward?
The "connection refused" issues are seeming to be becoming systemic, @rg305.
From Dig:
gonsernas.zapto.org. 59 IN A 77.21.252.87
zapto.org. 59 IN A 8.23.224.108
zapto.org. 59 IN SOA nf1.no-ip.com. hostmaster.no-ip.com. 2079748854 90 120 604800 60
From Let's Debug:
Yes there is a FritzBox, but i thought i open the Ports for this.
Here is what i got:
Unbenannt
That looks good. Are you able to visit your own website using a standard browser?
No, there will be a timeout. Dont know why.
Is your server located in the same region as your browsing device?
Dont know how to get that information. sorry !
I'm not familiar with that box.
And your picture doesn't show the internal IP being forwarded to (no need for it - but you need to ensure it can be reached).
That said, can you reach your site from any other device (not on that network - like from a smartphone)?
Get with us here, Rudy. :wink:
No i cant. tested it. No Connection
I think @rg305 was leading to the same thing I was though. Did you test from outside your network, specifically?
I turn my head and miss six posts! - LOL
How's a guy supposed to enjoy a cold :beer:?
Happens to the best of us, brother. Half the time I ask for things in the original post. :rofl:
Yes i tested it from "outside"
Well then you need to speak with your ISP or check your firewall/IPS/GeoLocation blocking devices.
We are not alone when we say: Your site can't be reached from the Internet.
That said, there is always DNS authentication...
Dont know what else to do..IPS?
IPS = Intrusion Prevention System
If you don't know what it means, you probably don't have one.
