Script that has been working for years stopped working after Feb
My domain is: FCSBOE.org
I ran this command: SRC=/etc/letsencrypt/live/mdm.sys.fcsboe.org
DST=/usr/local/filewave/certs
Backup both sets of certs
tar -cvf /etc/letsencryptbackup.tar /etc/letsencrypt
tar -cvf /usr/local/filewave/certsbackup.tar /usr/local/filewave/certs
Grab the new cert
certbot renew force
Update
\cp -uf $SRC/fullchain.pem $DST/server.crt
\cp -uf $SRC/privkey.pem $DST/server.key
Domain: mdm.sys.fcsboe.org
Type: connection
Detail: Fetching
http://mdm.sys.fcsboe.org/.well-known/acme-challenge/D2arkr_mwi9nG2PAs_flgfun o7r2fGl3lF25uAYjqUQ:
Connection refused
The operating system my web server runs on is (include version): Centos 7
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):1.3.0
I just took over a small network that uses LetsEncrypt get a cert for filewave, It uses a script to renew the script, looks like last successfully ran in Feb, I posted the script and output above, New to this procedure What am I missing?
Hi @Randidly
your http doesn't work. That's required if you want to use http validation.
Firewall, router. Not running webserver - a lot of things possible.
You need a working http website.
PS: There is a check of your domain, created yesterday - mdm.sys.fcsboe.org - Make your website better - DNS, redirects, mixed content, certificates
Only Grade V
ConnectFailure - Unable to connect to the remote server
A Grade A of the /.well-known/acme-challenge/random-filename - check minimal is required.
