Scattered certificates and keys
growyournestegg.com
sudo certbot install -d growyournestegg.com -d www.growyournestegg.com -v --preferred-challenges http
Root logging level set at 10
Saving debug log to /etc/apache2/sites-available/~/.certbot/logs/letsencrypt.log
Requested authenticator None and installer None
Apache version is 2.4.18
Single candidate plugin: * apache
Description: Apache Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: apache = certbot_apache.entrypoint:ENTRYPOINT
Initialized: <certbot_apache.override_debian.DebianConfigurator object at 0x7fcf411286a0>
Prep: True
Selected authenticator None and installer <certbot_apache.override_debian.DebianConfigurator object at 0x7fcf411286a0>
Plugins selected: Authenticator None, Installer apache
Which certificate would you like to install?
1: affordablesouthwesthomes.com
2: chocoholic.com
3: growyournestegg.com
4: winetreefarm.com
Select the appropriate number [1-4] then [enter] (press ā€˜c’ to cancel): 3
Created an SSL vhost at /etc/apache2/sites-available/growyournestegg.com-le-ssl.conf
Creating backup of /etc/apache2/sites-available/growyournestegg.com-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/growyournestegg.com-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/growyournestegg.com-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ā€˜c’ to cancel): 2
Creating backup of /etc/apache2/sites-enabled/growyournestegg.com.conf
Redirecting vhost in /etc/apache2/sites-enabled/growyournestegg.com.conf to ssl vhost in /etc/apache2/sites-available/growyournestegg.com-le-ssl.conf
Already enabled redirect for this vhost
Server version: Apache/2.4.18 (Ubuntu)
Server built: 2019-04-03T13:34:47
Ubuntu 16.04
Running on a self managed VPS hosted by A2.hosting
YES
NO (ssh to a terminal interface)
certbot 0.31.0
Problem
growyournestegg.com does not appear in ā€˜/etc/letsencrypt/live’ which is where I thought all letsencrypt generated certificates and keys were stored.
A number of my certs and keys are stored in:
/etc/apache2/sites-available/~/.certbot/config/live/
and some in:
/usr/share/wordpress/~/.certbot/config/live/
and there are even some in:
~/~/.certbot/config/live
Is it something that I’m doing that is scattering certificates all over the place?
Also when trying to access: growyournestegg.com
it goes to:
affordablesouthwesthomes.com which creates a ā€œSSL_ERROR_BAD_CERT_DOMAINā€ error
ā€œaffordablesouthwesthomes.comā€ which is the default server listed by ā€œsudo apache2 -Sā€ it’s also the first site listed in /etc/letsencrypt/live.
I don’t know what’s causing certs and keys to be scattered all over the file system? Could it be the phase of the moon?
-Pete
When I try to access growyournestegg.com
Hi @renopete
checking your first domain I don't see a problem.
Instead, you have a Grade B, that's very good ( https://check-your-website.server-daten.de/?q=growyournestegg.com ):
The certificate:
CN=growyournestegg.com
	25.04.2019
	24.07.2019
expires in 90 days
growyournestegg.com, www.growyournestegg.com - 2 entries
And all 4 standard checks are fine, two correct redirects http -> https, one correct not-preferred-version -> preferred version:
• http://growyournestegg.com/
198.100.45.83 301 https://growyournestegg.com/ 0.240 A
• http://www.growyournestegg.com/
198.100.45.83 301 https://www.growyournestegg.com/ 0.240 A
• https://growyournestegg.com/
198.100.45.83 301 https://www.growyournestegg.com/ 1.817 B
• https://www.growyournestegg.com/
198.100.45.83 200 1.697 B
Grade B is really good. Looks like you have fixed the problem.
Or it's a local caching problem, so only you see the wrong data.
Juergen
You were right. I checked late this evening on:
https://www.sslshopper.com/ssl-checker.html#hostname=growyournestegg.com
And it does not report a name mismatch. Am going to have to reboot my systems to see if
I can clear the browser caches of bad data.
Thanks for the quick response. As for letsencrypt storing all certificates and keys in
/etc/letsencrypt/live, I guess that’s not longer the case.
-Pete
Certbot does normally store everything in /etc/letsencrypt.
Check /etc/letsencrypt/cli.ini (ironically) and ~/.config/letsencrypt/cli.ini to see if there are settings telling it to put stuff elsewhere?
It sounds like perhaps something is configured to put things in ā€œ~/.config/certbotā€ but the ā€œ~ā€ isn’t being expanded.
