I am running Ubuntu with Apache 2.4.7 (with libaugeas0 package also installed). After downloading successfully, I run the command ./certbot-auto --apache and it returns:
Usage: certbot-auto [OPTIONS]
A self-updating wrapper script for the Certbot ACME client. When run, updates
to both this script and certbot will be downloaded and installed. After
ensuring you have the latest versions installed, certbot will be invoked with
all arguments you have provided.
Help for certbot itself cannot be provided until it is installed.
--debug attempt experimental installation
-h, --help print this help
-n, --non-interactive, --noninteractive run without asking for user input
--no-self-upgrade do not download updates
--os-packages-only install OS dependencies and exit
-v, --verbose provide more output
All arguments are accepted and forwarded to the Certbot client when run.
But nothing else happens. Am I doing something wrong? Running ./certbot-auto certonly seems to work as normal. How do I even begin to debug why it's not working?
