Right way to delete or remove expired certificate
Hello,
I am using Let’s Encrypt SSL certificate for Exchange Server 2019. The scheduler is working fine with renewal. I want to delete Let’s Encrypt expired certificate from ECP (Exchange Control Panel). What is the correct way?
Thanks
Ram
Any way should be fine: what does the Exchange Server 2019 documentation say?
As per Microsoft - The expired certificate can be removed using ECP or EMS. Through ECP just select the expired certificate and delete. Through EMS Get-ExchangeCertificate & Remove-ExchangeCertificate -Thumbprint xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
I will go with EAC.
Ram
