I have a problème for install / renew my let’s encrypt certificate.
Let me explain, when I try to renew or install a let encryption certificate, I have the following message:
Erreur : Wrote file to
/tmp/acme-challenge-public/ghvmCOYNcQsZ-jbF5C-LUMT-UNIlibybublhujbuylhjn, but couldn't download
http://mydomaine.tld/.well-known/acme-challenge/ghvmCOYNqsdcQsZ-jqsdqsbF5Ca-LUMgddfsT-qhyeaicuygfiauzegycfnaieuzgyncaizueygfcnaizuegfycnazie
Erreur : Certificate installation for mydomaine.tld failed !
For me, it’s not a DNS problem; my DNS configuration is :
@ 10800 IN A 192.99.xxx.xxx
@ 10800 IN AAAA xxxx:xxxx:xxxx:xxxx::1
@ 10800 IN MX 10 spool.mail.gandi.net.
@ 10800 IN MX 50 fb.mail.gandi.net.
@ 10800 IN SOA ns1.gandi.net. hostmaster.gandi.net. 1509211470 10800 3600 604800 10800
_xmpp-client._tcp 1800 IN SRV 0 5 5222 mydomaine.tld.
_xmpp-server._tcp 1800 IN SRV 0 5 5269 mydomaine.tld.
imap 10800 IN CNAME access.mail.gandi.net.
pop 10800 IN CNAME access.mail.gandi.net.
smtp 10800 IN CNAME relay.mail.gandi.net.
Where A and AAAA are respectively the IPv4 and IPv6 addresses of my server.
And when I execute the following command : dig mydomaine.tld
I have : mydomain.tld. 10799 IN A 192.99.xxx.xxx
So for me it’s correct.
And here is what I understand least: When I try with a web browser to download the file it works …
All traffic arriving on my proxmox server is redirected via iptables to the PFSense. (except 2 ports, one for the web interface and another for ssh access.)
And the web traffic (80 and 443) is redirected to my Yunohost server (NAT and rule).
My main problem is that i can not install a new let’s encrypt certificate.
When I try, I have :
But :
I can access my site in https, when it is configured with a self-signed certificate.
( I talked about Yunohost but I have the same problem with the following configuration: Debian 8 (fresh install) + nginx server + acme client. )
Quickly, Yunohost is Self-hosting distribution based on Debian GNU/Linux.
But, I don’t speak English very wel, so I prefer to invite you to click on the following links:
Yes and yes.
And if I try to create a file in this directory in cli.
For example : echo "TEST" >> /tmp/test
I can download the file with the following command tatafrom my laptop
Or I can access it from a web browser.
My domain is charbowicz.fr
You can test : http://charbowicz.fr/.well-known/acme-challenge/test
