Reported 'expired certificate' when using DNS-over-tls on an android with letsencrypt cert
Hi there, I'm using letsencrypt cert for my AdGuardHome dns server. At first, all things were fine. However, my android phone can't use the DNS-over-tls nowadays, and the AdGuardHome's log shows that '2022/06/07 20:20:49.989204 [error] handling tcp: reading msg: reading len: remote error: tls: expired certificate'. I'm very sure that my certs are up-to-date, and there's no changes after force-renewing. Then I tried zerossl and the problem was solved, so I believed that it may be an issue related to letsencrypt.
My android phone is Oneplus 9 running Android 12. I have also tried on a Huawei device running Android 10.
Thanks in advance.
My domain is:dns.jimmyshjj.top (use tls://dns.jimmyshjj.top:853 for DOT)
My web server is (include version):Adguardhome v0.108.0-b.9/ Nginx(for https server, which works fine)
The operating system my web server runs on is (include version):Ubuntu 22.04
My hosting provider, if applicable, is: Tencent Cloud
The version of my client is: certbot 1.21.0
Have you read?:
Thanks, It works. I remember that I have tried it before and it didn't work, maybe i remember wrong. Sorry for disturbing.
To me it feels like each Android revision and manufactures' configuration are unique enough that just saying Android is a bit too ambiguous. Maybe it is just me.
