Renewed certificate does not work in Tomcat
The certificate is renewed without errors but when starting the tomcat the tomcat fails when starting the NioSelectorPool protocol.
In order to continue operating we had to point to the pem files of the certificates from the previous renewal in the archive directory (we still have days left). It is an automatic renewal that always worked correctly and this time it started to give this error.
Error in catalina.out:
java.security.KeyStoreException: Cannot store non-PrivateKeys
StackTrace:
org.apache.catalina.LifecycleException: Failed to initialize component [Connector[HTTP/1.1-443]]
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:112)
at org.apache.catalina.core.StandardService.initInternal(StandardService.java:552)
at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:107)
at org.apache.catalina.core.StandardServer.initInternal(StandardServer.java:875)
at org.apache.catalina.startup.Catalina.load(Catalina.java:632)
at org.apache.catalina.startup.Catalina.load(Catalina.java:655)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.apache.catalina.startup.Bootstrap.load(Bootstrap.java:309)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:492)
Caused by: org.apache.catalina.LifecycleException: Protocol handler initialization failed
at org.apache.catalina.connector.Connector.initInternal(Connector.java:995)
...12 more
Caused by: java.lang.IllegalArgumentException: Cannot store non-PrivateKeys
at org.apache.tomcat.util.net.AbstractJsseEndpoint.createSSLContext(AbstractJsseEndpoint.java:115)
at org.apache.tomcat.util.net.AbstractJsseEndpoint.initialiseSsl(AbstractJsseEndpoint.java:86)
at org.apache.tomcat.util.net.NioEndpoint.bind(NioEndpoint.java:244)
at org.apache.tomcat.util.net.AbstractEndpoint.init(AbstractEndpoint.java:1087)
at org.apache.tomcat.util.net.AbstractJsseEndpoint.init(AbstractJsseEndpoint.java:265)
at org.apache.coyote.AbstractProtocol.init(AbstractProtocol.java:581)
at org.apache.coyote.http11.AbstractHttp11Protocol.init(AbstractHttp11Protocol.java:68)
at org.apache.catalina.connector.Connector.initInternal(Connector.java:993)
... 13 more
Caused by: java.security.KeyStoreException: Cannot store non-PrivateKeys
at sun.security.provider.JavaKeyStore.engineSetKeyEntry(JavaKeyStore.java:258)
at sun.security.provider.JavaKeyStore$JKS.engineSetKeyEntry(JavaKeyStore.java:56)
at sun.security.provider.KeyStoreDelegator.engineSetKeyEntry(KeyStoreDelegator.java:117)
at sun.security.provider.JavaKeyStore$DualFormatJKS.engineSetKeyEntry(JavaKeyStore.java:70)
at java.security.KeyStore.setKeyEntry(KeyStore.java:1140)
at org.apache.tomcat.util.net.jsse.JSSEUtil.getKeyManagers(JSSEUtil.java:225)
at org.apache.tomcat.util.net.AbstractJsseEndpoint.createSSLContext(AbstractJsseEndpoint.java:113)
...20 more
I ran this command: sudo certbot renew --force-renewal -d example.com (my domain)
It produced this output: java.security.KeyStoreException: Cannot store non-PrivateKeys
web server: Apache Tomcat/8.5.34
The operating system my web server runs on is (include version): Ubuntu 22.04.3 LTS
Used certbot 3.1.0
Could you help me?
Thank you
Welcome to the Let's Encrypt Community.
You need to provide your actual domain name before anyone can do that.
Please do not use that option. It doesn't magically fix any underlying problem and it often tends to create new problems with rate limiting.
Onve you provide your actual domain name we can confirm the status of your certificate. Then if anyone here is familiar with Tomcat, they may then be able offer further guidance.
Thank you for helping us to help you.
Domain is web.aulanexo.com
Thanks!
The same thing happens with another domain with the same configuration on another server.
Domain: staging.aulanexo.com
Regards
You appear to have obtained three EC certificates and an RSA certificate for web.aulanexo.com today, as well as an RSA certificate yesterday and another RSA certificate the day before.
What shows when you run sudo certbot certificates? (Please use </> Preformatted text to preserve formatting and make it easier for us to read.)
Here is output for sudo certbot certificates:
Found the following certs:
  Certificate Name: web.aulanexo.com
    Serial Number: 46ea6632f64e16beda1fe1495fb7deeec72
    Key Type: ECDSA
    Domains: web.aulanexo.com
    Expiry Date: 2025-04-14 01:02:00+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/web.aulanexo.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/web.aulanexo.com/privkey.pem
Thanks!
Certbot does not try to save certificates or private key into the Java KeyStore
Do you have a hook that does that?
I don't think the problem is Java KeyStore. It's a domain that has been around for a long time and has had many automatic renewals with letsencrypt and certboot. As a workaround, we reconfigured tomcat with the .pem files from the "archive" directory prior to the last renewal (they are valid for a few more days) and it works.
It works with the previous files and it doesn't work with the renew ones. The only thing that changes are the files that certboot installs in the renew.
Thanks for your help
You should refer Tomcat directly to the .../live/ folder instead. Those are symlinks to the most recent set of cert files in /archive. Pointing directly at the numbered set of files in /archive is not recommended.
Why is that only a work-around? Can't you just use the .pem files permanently?
I don't see any problem except about the Java KeyStore. I don't know enough about it to debug that. Maybe a different volunteer will know. Or, have you tried a KeyStore support forum?
Only as a workaround.
Because the certificate expires in a few days and I will have the problem when it is invalid.
I don't think the problem is Java KeyStore. Only the .pem files change on a renewal.
Thanks for your help!
But, Certbot should not fail to renew with that error. It does not update the KeyStore itself. Do you have a hook or something that does that?
What does this show?
sudo grep -iR hook /etc/letsencrypt
You also said the cert renews without error. So, why do you now say it will expire?
Cerboot renews the certificate correctly!!! That error is from tomcat when it starts: catalina.out.
Yeah, but you said you could point Tomcat directly to the .pem files in /archive and that worked. It was just that you were pointed to a soon-to-expire cert.
If you instead point Tomcat to the /live/ folder it will be the most recent cert. And, will always be the most recent cert. Why can't you just do that?
Can you check with e.g. openssl x509 -noout -text -in /path/to/cert.pem what the difference is between the working PEM file and the not working PEM file?
Maybe Tomcat simply doesn't like ECDSA :man_shrugging:t2:
The presently being severed certificate here https://decoder.link/sslchecker/web.aulanexo.com/443 which is this certificate crt.sh | 15316691133 is a RSA certificate, I feel Osiris is most like correct about the ECDSA certificates and Tomcat.
As the certificate you showed above is
I see the files are similar to each other. Maybe you can see something different.
This is a long-running production site that has this configuration without modifications. If Tomcat doesn't like ECDSA it shouldn't have worked before?
Old .pem file
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            03:a7:7b:a9:9b:e9:ba:85:4c:d4:9c:58:a4:37:6b:f2:54:27
    Signature Algorithm: sha256WithRSAEncryption
        Issuer: C=US, O=Let's Encrypt, CN=R11
        Validity
            Not Before: Nov 12 03:03:40 2024 GMT
            Not After : Feb 10 03:03:39 2025 GMT
        Subject: CN=web.aulanexo.com
        Subject Public Key Info:
            Public Key Algorithm: rsaEncryption
                Public-Key: (2048 bit)
                Modulus:
                    00:d5:a3:5b:fa:b6:a1:0d:04:1c:3f:e1:90:55:00:
                    b4:9f:d1:e0:3f:86:b3:5c:da:b2:24:c8:6b:a1:22:
                    1b:43:88:19:b7:94:c0:bb:0a:2a:18:b6:36:55:e4:
                    7c:80:dc:5a:6c:17:31:8d:45:95:05:ff:13:71:74:
                    72:51:f4:ca:93:64:0f:1f:04:64:aa:49:d2:d9:75:
                    d8:bc:ec:01:89:60:e9:d2:b9:f2:7b:f2:31:09:a4:
                    c7:9a:91:bc:b7:bf:12:f8:8d:6c:6f:98:be:86:3a:
                    d3:b8:c5:bc:9a:98:9a:8d:e8:6c:3c:5d:1f:2e:7d:
                    99:84:17:ec:1b:ce:3f:79:61:3a:8c:f9:53:98:a3:
                    68:98:dd:39:5a:ca:29:3b:a4:db:f0:8f:cd:c0:04:
                    26:a2:bf:c7:96:1e:eb:91:5f:3b:5c:db:29:7c:85:
                    a5:e8:e7:c5:57:82:83:5e:03:a0:2f:db:25:c4:78:
                    1e:19:09:56:a8:1d:8c:6d:ea:b0:c5:55:e4:0f:dc:
                    9a:fd:97:c4:8c:07:47:b9:09:be:07:7d:f9:5c:01:
                    a9:20:82:12:ae:fd:05:3d:de:5b:fb:1f:b9:3c:9c:
                    de:cc:fb:8b:eb:ba:30:fe:22:23:4e:e1:bd:ca:dd:
                    b4:8a:e8:75:ad:b6:bb:89:a0:2b:55:1a:29:ae:68:
                    31:29
                Exponent: 65537 (0x10001)
        X509v3 extensions:
            X509v3 Key Usage: critical
                Digital Signature, Key Encipherment
            X509v3 Extended Key Usage:
                TLS Web Server Authentication, TLS Web Client Authentication
            X509v3 Basic Constraints: critical
                CA:FALSE
            X509v3 Subject Key Identifier:
                7E:DD:B7:3C:06:C1:BA:F3:0B:01:17:FA:30:AA:6F:FE:15:9B:DB:E4
            X509v3 Authority Key Identifier:
                keyid:C5:CF:46:A4:EA:F4:C3:C0:7A:6C:95:C4:2D:B0:5E:92:2F:26:E3:B9
            Authority Information Access:
                OCSP - URI:http://r11.o.lencr.org
                CA Issuers - URI:http://r11.i.lencr.org/
            X509v3 Subject Alternative Name:
                DNS:web.aulanexo.com
            X509v3 Certificate Policies:
                Policy: 2.23.140.1.2.1
            CT Precertificate SCTs:
                Signed Certificate Timestamp:
                    Version   : v1(0)
                    Log ID    : 7D:59:1E:12:E1:78:2A:7B:1C:61:67:7C:5E:FD:F8:D0:
                                87:5C:14:A0:4E:95:9E:B9:03:2F:D9:0E:8C:2E:79:B8
                    Timestamp : Nov 12 04:02:10.275 2024 GMT
                    Extensions: none
                    Signature : ecdsa-with-SHA256
                                30:46:02:21:00:A1:8E:3E:C8:A9:97:B2:7E:E8:66:35:
                                17:3B:F1:BB:43:71:6C:43:FB:EB:F8:B1:21:29:BA:83:
                                9E:B0:AA:A4:93:02:21:00:C0:5C:AF:B2:73:AD:D0:99:
                                52:50:B4:2D:0F:7C:42:30:EB:97:6E:77:8A:F9:93:D6:
                                E0:6F:D2:0B:51:AA:FC:42
                    Version   : v1(0)
                    Log ID    : 13:4A:DF:1A:B5:98:42:09:78:0C:6F:EF:4C:7A:91:A4:
                                16:B7:23:49:CE:58:57:6A:DF:AE:DA:A7:C2:AB:E0:22
                    Timestamp : Nov 12 04:02:10.523 2024 GMT
                    Extensions: none
                                30:45:02:21:00:DB:7B:A8:A7:43:5A:F8:FC:81:05:1E:
                                3A:B3:3F:FA:5B:7C:98:B6:BA:6C:44:BD:1F:91:8E:24:
                                AA:07:23:99:00:02:20:30:10:6B:18:7A:AD:A0:5F:3E:
                                5D:66:60:F4:49:F1:B8:74:E0:70:74:A9:B6:AF:12:9B:
                                2B:D8:0F:1A:3A:20:BB
         a2:dd:be:81:60:d8:68:56:8f:52:f9:a6:e1:5b:32:a6:9b:07:
         dc:ed:0b:7d:1d:75:24:68:34:5c:3a:7e:a2:ab:8b:3d:29:a7:
         f5:7c:d0:cc:30:27:46:33:40:4f:7f:e7:f2:f5:08:2e:4a:cb:
         0b:47:d6:0d:80:54:be:19:9f:0c:a2:10:34:94:4e:26:a1:37:
         53:58:ef:9f:8b:a9:3a:7b:5e:b7:4c:04:84:50:fd:95:28:3c:
         16:69:66:e9:08:71:5f:ac:03:32:9b:22:59:d8:2c:a8:c9:8f:
         58:ec:36:3e:12:64:16:98:5c:f2:9e:39:ce:e9:f6:27:a4:68:
         10:f2:5e:19:dc:42:48:a2:f7:95:df:fd:54:55:d3:9b:e0:bc:
         4a:a0:8c:ae:fc:56:ef:9d:47:31:f0:9f:64:61:0d:14:b3:22:
         b6:0e:e7:45:08:1d:3a:35:16:32:f8:3c:ee:cd:92:9d:ef:b9:
         c0:69:9a:eb:bb:d4:c6:2c:79:6b:78:16:72:bb:ee:32:fc:d0:
         47:18:b2:0b:67:66:4e:5a:30:18:f2:99:e6:31:83:55:0f:e1:
         52:9a:ac:dc:2e:c7:da:ca:76:c6:9c:26:15:0b:43:b1:65:18:
         e7:71:6d:dc:27:83:a0:00:75:26:af:0b:42:bb:d9:a3:48:9d:
         c2:0d:e1:aa
Renew .pem file
Certificate:
    Data:
        Version: 3 (0x2)
        Serial Number:
            03:e1:02:bf:8a:4f:35:41:11:21:ab:fa:78:b2:cf:73:6c:89
        Validity
            Not Before: Jan 13 16:41:55 2025 GMT
            Not After : Apr 13 16:41:54 2025 GMT
                Modulus:
                    00:94:31:f3:54:60:03:9a:bf:8c:58:6d:27:31:a4:
                    9d:63:5a:53:40:ba:9a:f2:82:b3:71:79:41:57:7a:
                    98:a1:01:80:f3:9c:9a:a3:96:3c:ca:31:ee:03:fa:
                    69:8e:4b:08:fa:14:03:dc:67:89:ec:c7:e8:71:3e:
                    9b:16:31:91:71:f3:28:8e:39:44:cb:4c:5a:04:a3:
                    99:03:90:fe:83:93:54:75:6f:99:02:82:62:bc:32:
                    26:4e:c1:98:4a:78:3a:94:26:13:2d:71:16:7c:b2:
                    83:bb:71:2b:81:5e:be:bd:93:b7:a0:1c:37:92:22:
                    b5:a7:aa:7d:b1:17:e4:e9:a5:26:e3:a4:36:0f:3b:
                    93:30:bf:8e:38:ff:b5:df:6a:13:21:ab:f9:96:b2:
                    a9:0b:c6:4f:39:25:19:69:5a:48:36:d0:1c:38:76:
                    57:75:6c:65:7a:f6:3b:42:c0:53:ef:7f:4b:5c:5b:
                    04:c0:ee:37:77:b7:16:45:f6:a5:bd:53:c7:00:1e:
                    e4:39:94:b5:69:d4:18:a9:4f:bc:93:65:b5:52:0a:
                    99:70:b3:78:8d:d6:6c:d3:80:90:e8:da:4e:b7:b1:
                    46:b6:2a:31:fe:22:da:83:69:ab:0d:71:e2:bd:21:
                    58:a5:d1:c6:57:fb:aa:4b:95:a3:fe:2f:f8:48:36:
                    55:a9
        X509v3 extensions:
                CA:FALSE
                61:06:1D:B9:9F:80:1B:44:5E:D5:55:43:CE:D2:49:48:D2:D8:BF:36
                    Version   : v1(0)
                    Log ID    : 73:20:22:0F:08:16:8A:F9:F3:C4:A6:8B:0A:B2:6A:9A:
                                4A:00:EE:F5:77:85:8A:08:4D:05:00:D4:A5:42:44:59
                    Timestamp : Jan 13 17:40:25.173 2025 GMT
                    Extensions: none
                                30:45:02:20:51:00:1E:BA:86:7C:DD:5C:72:67:38:CD:
                                B0:90:3B:26:29:EF:48:2F:60:EE:79:CE:2D:11:3D:82:
                                E8:94:F4:63:02:21:00:B2:BA:D0:F9:B4:24:63:AA:10:
                                D5:E4:FB:8D:42:A8:64:14:A0:BE:9E:8F:73:1C:F1:27:
                                A6:4D:EC:3A:9F:9E:4E
                    Version   : v1(0)
                    Log ID    : CF:11:56:EE:D5:2E:7C:AF:F3:87:5B:D9:69:2E:9B:E9:
                                1A:71:67:4A:B0:17:EC:AC:01:D2:5B:77:CE:CC:3B:08
                    Timestamp : Jan 13 17:40:25.227 2025 GMT
                    Extensions: none
                                30:46:02:21:00:86:75:A6:61:1C:C0:B4:6C:DF:7F:52:
                                50:43:8E:C3:DE:04:CC:31:79:28:10:E9:CF:16:30:52:
                                AC:61:C0:B1:72:02:21:00:83:FB:CD:E0:F2:31:92:76:
                                05:6C:04:6C:FC:2A:02:93:E0:D8:5F:F5:8B:60:EC:68:
                                47:0F:C9:FE:1F:12:77:9F
         52:51:4d:4b:ee:d9:e0:6f:62:d6:d9:25:5a:ba:c5:37:b4:ba:
         30:56:2f:7e:bb:ed:11:8b:da:8b:3d:e6:1a:ac:84:8d:b7:d7:
         5f:04:55:98:7e:1d:f1:a2:fa:8d:b8:50:cd:3a:7e:22:bb:09:
         f1:89:57:8a:07:75:8d:d3:e9:99:88:66:11:e6:07:27:93:df:
         14:04:e9:d2:86:6b:8c:7b:f1:01:a6:ef:e2:7e:d6:a0:2d:9b:
         5f:d8:ea:0b:c0:cf:f4:f0:4a:61:9e:96:7a:c0:36:de:a6:2b:
         b0:08:d9:05:72:f1:52:4d:d6:1d:62:48:2e:e1:b2:23:f3:64:
         77:a3:9d:0f:23:7e:26:8d:1d:a0:70:e9:56:b9:80:17:de:67:
         97:86:e0:cd:af:ea:e2:df:a6:93:21:f9:65:ec:16:2f:d4:f6:
         d4:45:88:ce:bd:04:b9:ce:e0:51:67:95:f9:16:13:90:b1:b5:
         fc:19:70:d9:08:6d:63:6c:32:a4:28:90:a0:5c:5e:c8:01:c0:
         e0:b7:11:1e:0b:57:5b:0b:0c:83:2e:b0:00:a1:97:df:34:d3:
         56:b9:92:9a:89:b5:cd:02:8c:9c:a2:cb:68:47:6a:76:e2:a5:
         ef:66:99:c0:b0:88:67:1d:a2:f1:96:70:1a:2d:db:a1:74:58:
         e4:37:7b:a8
Thanks,
But the currently being served certificate is not an ECDSA, it is a RSA certificate.
And @Bruce5051 could you see if that changed between the previous certificate and the renewed one in the files I shared in the previous reply? I don't see any significant differences between the files.
Thanks!
Hi @VictorCoya here is a list of issued certificates https://crt.sh/?q=web.aulanexo.com
The ones with an Issuer Name
starting with C=US, O=Let's Encrypt, CN=E are ECDSA requested and issued certificates.
starting with C=US, O=Let's Encrypt, CN=R are RSA requested and issued certificates.
That is exactly what causes the error: the certified renew.
Thanks,
