Sorry. Wrong log. Here are the last 3 messages in the nginx error log:
2024/01/07 15:53:17 [crit] 8237#8237: *15 SSL_do_handshake() failed (SSL: error:14201044:SSL routines:tls_choose_sigalg:internal error) while SSL handshaking, client: 172.104.25.248, server: 0.0.0.0:443
2024/01/07 16:07:35 [crit] 8237#8237: *61 SSL_do_handshake() failed (SSL: error:14209102:SSL routines:tls_early_post_process_client_hello:unsupported protocol) while SSL handshaking, client: 170.64.128.28, server: 0.0.0.0:443
2024/01/07 16:07:36 [crit] 8237#8237: *65 SSL_do_handshake() failed (SSL: error:141CF06C:SSL routines:tls_parse_ctos_key_share:bad key share) while SSL handshaking, client: 170.64.128.28, server: 0.0.0.0:443
HTTPS must have worked prior to the upgrade, otherwise some clients would have displayed unsecured signals.
Does this test gives any more info?:
# openssl s_client -connect app.setpad.ca:443
CONNECTED(00000003)
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = app.setpad.ca
verify return:1
Certificate chain
0 s:CN = app.setpad.ca
2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
i:O = Digital Signature Trust Co., CN = DST Root CA X3
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=CN = app.setpad.ca
issuer=C = US, O = Let's Encrypt, CN = R3
Peer signing digest: SHA256
Peer signature type: RSA-PSS
Server Temp Key: X25519, 253 bits
SSL handshake has read 4512 bytes and written 385 bytes
Verification: OK
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Server public key is 2048 bit
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
Post-Handshake New Session Ticket arrived:
SSL-Session:
Protocol : TLSv1.3
Cipher : TLS_AES_256_GCM_SHA384
Session-ID: 7ECC43005A5D528F1FC9FB5D9236A6C5B276EE3CEE05AB60EFC7FDCD6458FA8F
Session-ID-ctx:
Resumption PSK: 9805785B4FA959FEA5A83C00D7C80711F3275D9B1171A7381DF6787B89A08291125083087448A99BBB9212D56783E124
PSK identity: None
PSK identity hint: None
SRP username: None
TLS session ticket lifetime hint: 300 (seconds)
TLS session ticket:
0000 - 1c 02 73 c0 d8 72 ed c0-d0 3e 00 1b 83 bf 5d 1e ..s..r...>....].
0010 - ae cd 76 68 14 33 6c f8-ae 66 5e 75 06 f5 4a df ..vh.3l..f^u..J.
0020 - 2f 50 e5 61 ca b2 3b 96-01 3a 5a 53 c0 73 76 83 /P.a..;..:ZS.sv.
0030 - 3b 96 86 7a 5e ed 52 e9-30 b3 e2 78 eb e0 8c f8 ;..z^.R.0..x....
0040 - 56 da 51 d1 53 51 41 4a-11 dc 9e 70 68 74 db f0 V.Q.SQAJ...pht..
0050 - cd 0a d9 24 6a f2 86 f9-1c 32 1d ab 99 b2 cd 2b ...$j....2.....+
0060 - 27 fe d3 cf 63 c1 38 b7-18 f7 78 6b bc b5 b1 98 '...c.8...xk....
0070 - 14 5c 1e 69 67 c8 11 3a-fa ea dd 65 a0 3f e9 c8 .\.ig..:...e.?..
0080 - 79 0d 48 52 41 32 96 1f-66 6a 9d f4 e7 23 f6 b2 y.HRA2..fj...#..
0090 - e5 a9 9e 97 df 31 7f 7c-f5 8f 9a 74 13 29 ba 6c .....1.|...t.).l
00a0 - 1d 6e bc ed be 5f 6a 76-fe e9 7d 67 7b 7a 2a 5f .n..._jv..}g{z*_
00b0 - 0b e8 80 66 84 48 bc 4a-e7 23 d3 91 58 b5 67 ba ...f.H.J.#..X.g.
00c0 - 80 e4 fd 18 49 d3 66 e2-e9 a2 3a 97 23 c4 07 fc ....I.f...:.#...
00d0 - d5 cf 22 b6 15 2b 63 a1-d4 a3 13 2f 19 dc e6 14 .."..+c..../....
Start Time: 1704661429
Timeout : 7200 (sec)
Extended master secret: no
Max Early Data: 0
nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
worker_connections 768;
# multi_accept on;
http {
# Basic Settings
sendfile on;
tcp_nopush on;
tcp_nodelay on;
keepalive_timeout 65;
types_hash_max_size 2048;
# server_tokens off;
# SSL Settings
#ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_protocols TLSv1.2; # Dropping SSLv3, ref: POODLE
ssl_prefer_server_ciphers on;
# Logging Settings
# Gzip Settings
gzip on;
gzip_disable "msie6";
# gzip_vary on;
# gzip_proxied any;
# gzip_comp_level 6;
# gzip_buffers 16 8k;
# gzip_http_version 1.1;
# Virtual Host Configs
include /etc/nginx/blacklist; ## NEW
#mail {
# # See sample authentication script at:
# # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
# # auth_http localhost/auth.php;
# # pop3_capabilities "TOP" "USER";
# # imap_capabilities "IMAP4rev1" "UIDPLUS";
# server {
# listen localhost:110;
# protocol pop3;
# proxy on;
# server {
# listen localhost:143;
# protocol imap;
# proxy on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-auth-pam.conf:
load_module modules/ngx_http_auth_pam_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-dav-ext.conf:
load_module modules/ngx_http_dav_ext_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-echo.conf:
load_module modules/ngx_http_echo_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-subs-filter.conf:
load_module modules/ngx_http_subs_filter_module.so;
# configuration file /etc/nginx/modules-enabled/50-mod-http-upstream-fair.conf:
load_module modules/ngx_http_upstream_fair_module.so;
types {
text/html html htm shtml;
text/css css;
text/xml xml;
image/gif gif;
image/jpeg jpeg jpg;
application/javascript js;
application/atom+xml atom;
application/rss+xml rss;
text/mathml mml;
text/plain txt;
text/vnd.sun.j2me.app-descriptor jad;
text/vnd.wap.wml wml;
text/x-component htc;
image/png png;
image/tiff tif tiff;
image/vnd.wap.wbmp wbmp;
image/x-icon ico;
image/x-jng jng;
image/x-ms-bmp bmp;
image/svg+xml svg svgz;
image/webp webp;
application/font-woff woff;
application/java-archive jar war ear;
application/json json;
application/mac-binhex40 hqx;
application/msword doc;
application/pdf pdf;
application/postscript ps eps ai;
application/rtf rtf;
application/vnd.apple.mpegurl m3u8;
application/vnd.ms-excel xls;
application/vnd.ms-fontobject eot;
application/vnd.ms-powerpoint ppt;
application/vnd.wap.wmlc wmlc;
application/vnd.google-earth.kml+xml kml;
application/vnd.google-earth.kmz kmz;
application/x-7z-compressed 7z;
application/x-cocoa cco;
application/x-java-archive-diff jardiff;
application/x-java-jnlp-file jnlp;
application/x-makeself run;
application/x-perl pl pm;
application/x-pilot prc pdb;
application/x-rar-compressed rar;
application/x-redhat-package-manager rpm;
application/x-sea sea;
application/x-shockwave-flash swf;
application/x-stuffit sit;
application/x-tcl tcl tk;
application/x-x509-ca-cert der pem crt;
application/x-xpinstall xpi;
application/xhtml+xml xhtml;
application/xspf+xml xspf;
application/zip zip;
application/octet-stream bin exe dll;
application/octet-stream deb;
application/octet-stream dmg;
application/octet-stream iso img;
application/octet-stream msi msp msm;
application/vnd.openxmlformats-officedocument.wordprocessingml.document docx;
application/vnd.openxmlformats-officedocument.spreadsheetml.sheet xlsx;
application/vnd.openxmlformats-officedocument.presentationml.presentation pptx;
audio/midi mid midi kar;
audio/mpeg mp3;
audio/ogg ogg;
audio/x-m4a m4a;
audio/x-realaudio ra;
video/3gpp 3gpp 3gp;
video/mp2t ts;
video/mp4 mp4;
video/mpeg mpeg mpg;
video/quicktime mov;
video/webm webm;
video/x-flv flv;
video/x-m4v m4v;
video/x-mng mng;
video/x-ms-asf asx asf;
video/x-ms-wmv wmv;
video/x-msvideo avi;
# configuration file /etc/nginx/conf.d/stub_status.conf:
# configuration file /etc/nginx/sites-enabled/setpad.ca:
# listen 80;
# listen [::]:80;
listen 443 http2 default_server;
listen [::]:443 http2 default_server;
root /var/www/html;
index index.html;
server_name setpad.ca www.setpad.ca app.setpad.ca;
add_header headerKey "headerValue" always; # CF added - 2020-07-02
ssl on;
ssl_certificate /etc/letsencrypt/live/app.setpad.ca/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/app.setpad.ca/privkey.pem; # managed by Certbot
location /htmlperso/ {
alias /var/www/htmlperso/;
#rewrite ^(.*)\/\/([a-zA-Z0-9-.:]*)\/?(.*)$ $2/$3 permanent;
try_files $uri $uri/ /htmlperso/index.html;
#try_files $uri $uri/ =404;
if ($block_ua) {
return 444;
location /app {
alias /var/www/html/app;
try_files $uri $uri/ /app/index.html;
if ($block_ua) {
return 444;
location /tempFiles {
alias /home/setpad-server/fsroot/tempFiles;
location /recptFiles {
alias /home/setpad-server/fsroot/recptFiles;
types { application/octet-stream .pdf; }
location /api/ {
proxy_read_timeout 1800s;
proxy_connect_timeout 1800s;
proxy_send_timeout 1800;
send_timeout 1800;
proxy_pass https://clone1.setpad.ca:5000/;
#proxy_pass https://localhost:5000/;
proxy_http_version 1.1;
proxy_buffers 8 64k;
proxy_buffer_size 128k;
proxy_set_header Connection 'upgrade';
proxy_set_header Host $host;
proxy_cache_bypass $http_upgrade;
location /hooks/stripe {
send_timeout 1800;
proxy_pass https://clone1.setpad.ca:5000/hooks/stripe;
proxy_set_header X-SSL-CERT $ssl_client_cert; # attention: Deprecated in recent versions. replaced by $ssl_client_escapte_cert
location /hooks/sgrid {
send_timeout 1800;
proxy_pass https://clone1.setpad.ca:5000/hooks/sgrid;
gzip on;
gzip_types application/javascript image/* text/css;
gunzip on;
ssl_ciphers 'ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-DSS-AES128-GCM-SHA256:kEDH+AESGCM:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA:ECDHE-ECDSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-DSS-AES128-SHA256:DHE-RSA-AES256-SHA256:DHE-DSS-AES256-SHA:DHE-RSA-AES256-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:AES:CAMELLIA:DES-CBC3-SHA:!aNULL:!eNULL:!EXPORT:!DES:!RC4:!MD5:!PSK:!aECDH:!EDH-DSS-DES-CBC3-SHA:!EDH-RSA-DES-CBC3-SHA:!KRB5-DES-CBC3-SHA';
ssl_dhparam /etc/letsencrypt/dhparams.pem;
if ($host = app.setpad.ca) {
} # managed by Certbot
if ($host = www.setpad.ca) {
if ($host = setpad.ca) {
listen 0.0.0.0:80;
rewrite ^ https://$host$request_uri? permanent;
# required by Amplify
listen 127.0.0.1:80;
server_name 127.0.0.1;
location /nginx_status {
stub_status;
# configuration file /etc/nginx/blacklist:
map $http_user_agent $block_ua {
default 0;
~*(adbeat_bot|ahrefsbot|alexibot|appengine|aqua_products|archive.org_bot|archive|asterias|attackbot|b2w|backdoorbot|becomebot|blackwidow|blekkobot) 1;
~*(blowfish|botalot|builtbottough|bullseye|bunnyslippers|ccbot|cheesebot|cherrypicker|chinaclaw|chroot|clshttp|collector) 1;
~*(control|copernic|copyrightcheck|copyscape|cosmos|craftbot|crescent|curl|custo|demon) 1;
~*(disco|dittospyder|dotbot|download|downloader|dumbot|ecatch|eirgrabber|email|emailcollector) 1;
~*(emailsiphon|emailwolf|enterprise_search|erocrawler|eventmachine|exabot|express|extractor|extractorpro|eyenetie) 1;
~*(fairad|flaming|flashget|foobot|foto|gaisbot|getright|getty|getweb!|gigabot) 1;
~*(github|go!zilla|go-ahead-got-it|go-http-client|grabnet|grafula|grub|hari|harvest|hatena|antenna|hloader) 1;
~*(hmview|htmlparser|httplib|httrack|humanlinks|ia_archiver|indy|infonavirobot|interget|intraformant) 1;
~*(iron33|jamesbot|jennybot|jetbot|jetcar|joc|jorgee|kenjin|keyword|larbin|leechftp) 1;
~*(lexibot|library|libweb|libwww|linkextractorpro|linkpadbot|linkscan|linkwalker|lnspiderguy|looksmart) 1;
~*(lwp-trivial|mass|mata|midown|miixpc|mister|mj12bot|moget|msiecrawler|naver) 1;
~*(navroad|nearsite|nerdybot|netants|netmechanic|netspider|netzip|nicerspro|ninja|nutch) 1;
~*(octopus|offline|openbot|openfind|openlink|pagegrabber|papa|pavuk|pcbrowser|perl) 1;
~*(perman|picscout|propowerbot|prowebwalker|psbot|pycurl|pyq|pyth|python) 1;
~*(python-urllib|queryn|quester|radiation|realdownload|reget|retriever|rma|rogerbot|scan|screaming|frog|seo) 1;
~*(scooter|searchengineworld|searchpreview|semrush|semrushbot|semrushbot-sa|seokicks-robot|sitesnagger|smartdownload|sootle) 1;
~*(spankbot|spanner|spbot|spider|stanford|stripper|sucker|superbot|superhttp|surfbot|surveybot) 1;
~*(suzuran|szukacz|takeout|teleport|telesoft|thenomad|tocrawl|tool|true_robot|turingos) 1;
~*(twengabot|typhoeus|url_spider_pro|urldispatcher|urllib|urly|vampire|vci|voideye|warning) 1;
~*(webauto|webbandit|webcollector|webcopier|webcopy|webcraw|webenhancer|webfetch|webgo|webleacher) 1;
~*(webmasterworld|webmasterworldforumbot|webpictures|webreaper|websauger|webspider|webster|webstripper|webvac|webviewer) 1;
~*(webwhacker|webzip|webzip|wesee|wget|widow|woobot|www-collector-e|wwwoffle|xenu) 1;
