Renewal with removal of subdomain
My domain is: jabber.org
Note that this is an XMPP server, not an HTTP server; we previously hosted two domains here, jabber.org and conference.jabber.org, but moved conference.jabber.org to a separate machine. Now when we try to renew the old certificate, we receive a warning about not being able to contact conference.jabber.org (see below). We modified a configuration file under /etc/letsencrypt/renewal to remove the webroot for conference.jabber.org before attempting to renew but that didn't help. Should we request a new certificate instead of attempting to renew?
I ran this command: /usr/local/letsencrypt/letsencrypt-auto --no-self-upgrade renew
Processing /etc/letsencrypt/renewal/jabber.org.conf
http-01 challenge for conference.jabber.org
http-01 challenge for jabber.org
Challenge failed for domain conference.jabber.org
Attempting to renew cert (jabber.org) from /etc/letsencrypt/renewal/jabber.org.conf produced an unexpected error: Some challenges have failed.. Skipping.
renew_before_expiry = 30 days
/etc/letsencrypt/live/jabber.org/fullchain.pem (failure)
My web server is (include version): apache2
The operating system my web server runs on is (include version): Debian 7.10 (yes, we know this is old)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): unsure
Welcome to the Let's Encrypt Community, Peter :slightly_smiling_face:
The domain names used for certificate renewal originate from the existing certificate itself. You can modify the certificate configuration using the following command, which will also update your configuration:
/usr/local/letsencrypt/letsencrypt-auto run --cert-name jabber.org -d "www.jabber.org,jabber.org" --no-self-upgrade
Consider using --cert-name instead of --expand, as it gives more control over which certificate is modified and it lets you remove domains as well as adding them.
https://certbot.eff.org/docs/using.html#re-creating-and-updating-existing-certificates
Current Certificate
Certificate History
https://crt.sh/?Identity=jabber.org&deduplicate=Y
You probably want to 301 redirect these to https:
Screenshot_20201013-143714_Samsung Internet
Hi @stpeter,
letsencrypt-auto --no-self-upgrade --expand --cert-name jabber.org -d jabber.org
should do the trick to remove the subdomain.
You could also use this flag while renewing:
--allow-subset-of-names
When performing domain validation, do not consider it
a failure if authorizations can not be obtained for a
strict subset of the requested domains. This may be
useful for allowing renewals for multiple domains to
succeed even if some domains no longer point at this
system. This option cannot be used with --csr.
(default: False)
Two possible solutions to your problem exist, one not so pleasant to hear, the other way more easy, but not without its drawback:
Unfortunately, it isn't straightforward to delete or add a hostname from or to a certificate. There has been ongoing discussion about fixing this on the certbot Github page:
Unfortunately closed "because --cert-name exists".
Later, somebody having issues because all the settings need to be re-entered on the command line opened:
Meanwhile, almost a year ago, another issue was opened because adding and removing domains is very cumbersome:
Unfortunately, these past 11 months, nothing seems to have changed.
So to answer your question with the first option: you could indeed re-request your original certificate, but now without the hostname you'd like to remove from the certificate. Use --cert-name to make sure the previous certificate is overwritten.
Second option: use the --allow-subset-of-names option when renewing. This would allow certbot to continue with getting your cert, but now without any failing hostname(s). Drawbacks: if a hostname fails when it shouldn't, because of for example a temporary issue, this hostname would be removed from the certificate too. Fortunately, you've already tried to renew. And only the non-functional hostname failed, right? If that's the case, the Let's Encrypt validation servers would have a cached valid authorization for the other hostnames, so this wouldn't be an issue. But it could be a theoretical issue nontheless.
As noted, we run an XMPP server at jabber.org - this is on a separate machine than the web server at www.jabber.org. Just to be clear about which cert is involved. :slight_smile:
Why is there a redirect from jabber.org to www.jabber.org? Is that in case of http requests to jabber.org? I may have answered my own question. :blush:
Hey _az both of these approaches look promising. Unfortunately, when running letsencrypt-auto I now experience a more fundamental problem:
Creating virtual environment...
Installing Python packages...
/opt/eff.org/certbot/venv/bin/python: No module named pip.main; 'pip' is a package and cannot be directly executed
File "/tmp/tmp.Ef2tkHKHOw/pipstrap.py", line 182, in
sys.exit(main())
File "/tmp/tmp.Ef2tkHKHOw/pipstrap.py", line 154, in main
pip_version = StrictVersion(check_output([python, '-m', 'pip', '--version'])
File "/usr/lib/python2.7/subprocess.py", line 544, in check_output
raise CalledProcessError(retcode, cmd, output=output)
subprocess.CalledProcessError: Command '['/opt/eff.org/certbot/venv/bin/python', '-m', 'pip', '--version']' returned non-zero exit status 1
So I'll need to fix that first! :slight_smile:
Can you please tell us your version?
/usr/local/letsencrypt/letsencrypt-auto --version
You can probably install the latest certbot via snap.
I get the same error about "no module named pip.main" when I attempt to run the foregoing command. :-/
Ah... K.
What OS are you using?
I'm blind today. Debian
cat /etc/debian_version
7.10
Thanks for that. :slightly_smiling_face:
You might be able to install the latest via snap using the following link. It requires you to remove your existing version as part of the process.
Yes, we know this is an ancient version of Debian. :slight_smile: We have a server migration in process so that we can upgrade this machine (thus the temporary split of domains causing the original issue).
This error is quite likely due to running letsencrypt-auto without --no-self-upgrade. Unfortunately when it tries to upgrade, it deletes the previous version of itself.
Debian 7, being very EOL, is not capable of upgrading to a recent version of certbot-auto. And you won't be able to use snaps on a kernel that old either.
You may need to restore certbot-auto from an old release like https://raw.githubusercontent.com/certbot/certbot/v0.40.0/certbot-auto, and then make sure to always use the --no-self-upgrade flag.
You can check exactly what version you had before by looking in /etc/letsencrypt/renewal/*.conf.
Thanks, griffin, for your fast and friendly service. I'll try the snap approach after my next round of meetings. :wink:
Read @_az's response first. His knowledge far exceeds mine here.
Yes, what @_az says makes sense!
You should still include both jabber.org and www.jabber.org on the certificate for your http and redirect http://jabber.org and http://www.jabber.org to https://www.jabber.org. :grin:
Let us know how things proceed. :slightly_smiling_face:
Thanks for the tip. The version we previously ran was 0.36.0. I downloaded that version from https://raw.githubusercontent.com/certbot/certbot/v0.36.0/certbot-auto but after typing /usr/local/letsencrypt/letsencrypt-auto --version I still get the error about "no module named pip.main". I suspect package corruption on this ancient Debian OS, from which recovery could be difficult...
Let me know whether it works if you follow this exact process:
  1. Delete the letsencrypt-auto and certbot-auto file.
  2. sudo rm -rf /opt/eff.org/certbot/
  3. wget https://raw.githubusercontent.com/certbot/certbot/v0.36.0/certbot-auto
  4. chmod +x certbot-auto
  5. ./certbot-auto --no-self-upgrade --version
The deletions are needed to get rid of all of the partially-upgraded software, and --no-self-upgrade is very important, even when doing --version.
Your actual certificate data is stored elsewhere and preserved.
