Renewal using certonly subcommand
I created a certificate using the 'certonly' subcommand for another machine. I now need to renew the certificate, however, the authentication process fails because the target machine sits behind a router which has its own web server listening on port 80. This means that certbot can't access the target machine.
Is it possible to specify a different port number for certbot to use for the challenge?
Here's the log of the attempt to renew the certificate:
Blockquote
certbot-auto certonly -d starlightproductions.ddnsfree.com --cert-path ~/certs/starlightproductions.crt
Requesting to rerun /usr/local/bin/certbot-auto with root privileges...
1: Spin up a temporary webserver (standalone)
2: Place files in webroot directory (webroot)
http-01 challenge for starlightproductions.ddnsfree.com
Challenge failed for domain starlightproductions.ddnsfree.com
Blockquote
Usually there is a way to re-assign the router's web admin port from 80 to something else, which frees up 80 to be used by port forwarding.
By the way, this is often bad OS reporting of different ICMP errors, such as "administratively prohibited" (from firewalls). I wish we had clearer socket-to-application reporting of these distinctions. nmap can seemingly see them and you can also see them with Wireshark. :shark:
(I agree with your interpretation, just complaining about the socket APIs!)
And that is the case here—Wireshark confirms that this is ICMP type 3, code 13 ("Communication administratively prohibited").
That's probably a good sign (the router denying ingress from the WAN side to its admin server) - as long as @pcameron60 can figure out how to move the router web server to another port, everything should just starting working.
Not really.
You can try use TLS-ALPN which uses port 443 instead, but it's a bit of a pain and not supported by Certbot. acme.sh is one that does support that mode, in case you do want to try it.
A third option is to try and use the DNS challenge. I see that your DDNS domain is operated by Dynu, so you might be able to use acme.sh's Dynu support to issue your certificate: dnsapi · acmesh-official/acme.sh Wiki · GitHub . If you can get this to work, I would definitely recommend it over the TLS-ALPN option.
Unfortunately, not in this case.
