My domain is: aquarius.je
I ran this command: certbot renew --dry-run
Fetching http://aquarius.je/.well-known/acme-challenge/cg6W1FJsdUAa2wpfqmOcbuRtwX0-yQcKKwGkFTzBd68: Timeout during connect (likely firewall problem)
Apache/2.4.52 (Ubuntu)
Ubuntu 22.04.1 LTS
ME
YES
NO
certbot 1.32.1
Further Info :
Port 80 is disabled - I won't run a web server with it enabled - regardless of the "port 80 doesn't matter"
DNS is hosted by myself on different servers using Bind.
I am struggling to renew a cert without having to go onto the server and use
ufw allow 80
certbot renew
ufw delete ....
I can add a record to DNS - just not via API - why should I have to enable port 80 for the challenge response ?
TIA for any pointers,
Mack
