Renewal problem; macOS Server 5.5
My domain is: sevardin.com
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/fates.org.conf
Cert not yet due for renewal
Processing /etc/letsencrypt/renewal/sevardin.com.conf
http-01 challenge for sevardin.com
Waiting for verification…
Attempting to renew cert (sevardin.com) from /etc/letsencrypt/renewal/sevardin.com.conf produced an unexpected error: Failed authorization procedure. sevardin.com (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://sevardin.com/.well-known/acme-challenge/4j16_Id4202qGhT8yF9tMMR9qRlyau-HGGLZUa779d8: "
404 Not Found
Not Found
<p". Skipping. All renewal attempts failed. The following certs could not be renewed: /etc/letsencrypt/live/sevardin.com/fullchain.pem (failure)
/etc/letsencrypt/live/fates.org/fullchain.pem (skipped)
Server version: Apache/2.4.28 (Unix)
Server built: Oct 9 2017 19:54:20
macOS High Sierra 10.13.3
I set up certs for two domains on this server: fates.org and sevardin.com. I am able to renew fates.org, but sevardin.com began failing with the above after the first round of renewals. I have tried placing a readable file in $WEBROOT/.well-known/acme-challenge and am able to view the file from a browser.
The machine where these domains are hosted crashed a few days ago—but after the first failed renewal attempt—and $WEBROOT has changed as a result. This change did not affect fates.org’s renewal. (I restored the machine from a backup from the day before I had renewed the fates.org certificate.) I have checked and verified permissions for the domain, verified the IP address, and am currently able to call up https://sevardin.com with the current certificate.
I’m at a loss for what to try next. The certificate for sevardin.com expires on 6 March 2018.
Please place a test file in the directory $WEBROOT/.well-known/acme-challenge/ (for sevardin.com) which we can try to access.
I added “foo.txt” to that directory and can access it at:
http://sevardin.com/.well-known/acme-challenge/foo.txt
Is the webroot directory in /etc/letsencrypt/renewal/sevardin.com.conf still the one you expect? (Remember that the webroot path itself should not contain the /.well-known/acme-challenge.)
Ah! That was it. Many thanks for your help. Changing the path fixed the renewal. (Why it still successfully renewed the other site, which also had a bad path, I have no idea… but am less concerned about that now.)
If you originally got the other certificate with -a apache or --apache, the CA would still allow a validation by the deprecated HTTPS-01 technology on port 443, which is unaffected by redirects. That's one possibility.
I obtained both original certs at the same time from letsencrypt.
