Renewal Let's Encrypt allows no more than 20 certificates to be issued
My domain is: labexato.com.br
try to renew the certificate, but gave error
It produced this output: The installation of the Let’s Encrypt SSL certificate failed: Remove certificate failure: One of the certificates you intend to exclude is used to protect Plesk
Plesk Onyx
Version 17.8.2
My hosting provider, if applicable, is: windows server 2012
I tried a few times, until I gave this error, how to solve it by what I understood, plesk requested the certificates but not active for me
Bom dia @sidnei_alves1,
It looks like you’re using KingHost. KingHost has claimed to have built-in support for Let’s Encrypt certificates in its hosting platform.
I would suggest that you should contact KingHost’s support because I think that they’ll be in a much better position to help you. (Nobody on this forum is responsible for the development of Plesk Onyx.)
