Could not renew Let's Encrypt certificates
lauroikastola.eus
Could not renew Let’s Encrypt certificates for Agurtzane Mentxaka (login admin). Please log in to Plesk and renew the certificates listed below manually.
Renewal of the following Let’s Encrypt certificates has failed:
The following Let’s Encrypt certificates have been renewed without some of their Subject Alternative Names:
Debian 8.11
OVH
YES
PLESK 17.8.11
Plesk Let’s Script extension versión 2.8.4-547
Hi @dc-maruri
looks like you have found a solution. Or you use a completely wrong command.
Checking your domain there is a new certificate - https://check-your-website.server-daten.de/?q=lauroikastola.eus
CN=lauroikastola.eus
	16.01.2020
	15.04.2020
expires in 89 days	lauroikastola.eus, www.lauroikastola.eus - 2 entries
If you use Plesk, use only Plesk, nothing else.
Your site isn't perfect (Grade E), but both connections (non-www and www) are secure.
And you have already created 4 identical certificates:
Let's Encrypt Authority X3 2020-01-15 2020-04-14 lauroikastola.eus, www.lauroikastola.eus
2 entries duplicate nr. 4
2 entries duplicate nr. 3
Let's Encrypt Authority X3 2020-01-14 2020-04-13 lauroikastola.eus, www.lauroikastola.eus
2 entries duplicate nr. 2
2 entries duplicate nr. 1
Let's Encrypt Authority X3 2020-01-10 2020-04-09 lauroikastola.eus, www.lauroikastola.eus
2 entries
Thanks JuergenAuer, so we don’t need to worry about the Let’s Script message we receive each day about the “Could not renew Let’s Encrypt certificates” ?
We only have used the Let’s Script plesk extension.
I don't know. But Letsencrypt doesn't send daily mails.
Read
PS: Sometimes users change their hoster. And the old system sends such mails. So check the header to find the ip of the sender and check, if this is your current system.
