Renewal Failure Starting 5/24/2024 403 Error
This domain was previously renewing OK. Fails with a 403 error (see log). Apache log shows 200 status for 3 accesses are 4 required? I removed any banned IPs from iptables (fail2ban running).
Apache access log below, nothing seen in error log.
3.137.167.13 77 - [24/May/2024:16:15:32 -0400] "GET /.well-known/acme-challenge/1KUPuuvTD2c_Azp1y6VRu9nxJ3WxTqFFx2bFNpWGSTc HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
23.178.112.200 56 - [24/May/2024:16:15:32 -0400] "GET /.well-known/acme-challenge/1KUPuuvTD2c_Azp1y6VRu9nxJ3WxTqFFx2bFNpWGSTc HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
35.93.112.118 69 - [24/May/2024:16:15:32 -0400] "GET /.well-known/acme-challenge/1KUPuuvTD2c_Azp1y6VRu9nxJ3WxTqFFx2bFNpWGSTc HTTP/1.1" 200 87 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
imaging.capecodexp.com
certbot renew
Processing /etc/letsencrypt/renewal/imaging.capecodexp.com.conf
Renewing an existing certificate for imaging.capecodexp.com
Domain: imaging.capecodexp.com
Detail: During secondary validation: 96.67.1.107: Invalid response from http://imaging.capecodexp.com/.well-known/acme-challenge/1KUPuuvTD2c_Azp1y6VRu9nxJ3WxTqFFx2bFNpWGSTc: 403
Failed to renew certificate imaging.capecodexp.com with error: Some challenges have failed.
/etc/letsencrypt/live/imaging.capecodexp.com/fullchain.pem (failure)
Server version: Apache/2.4.37 (AlmaLinux)
AlmaLinux release 8.8 (Sapphire Caracal)
no
certbot 2.5.0
Hello @chrisacdx,
Please read these:
Edit: definitely read those above; you have a geo blocking issue.
http://www.site24x7.com/tools/public/t/results-1716589186635.html
Edit:
This may show the issue even better Permanent link to this check report
Thank you Bruce5051, this was indeed a Geo Blocking issue, the check report site was very useful in detecting this problem, thanks again for your help.
