"Challenged failed for" when renewing expired certification
My domain is: crazyblockstech.com and www.crazyblockstech.com
certbot certonly --cert-name crazyblockstech.com -a apache -d crazyblockstech.com,www.crazyblockstech.com --dry-run
Plugins selected: Authenticator apache, Installer None
Simulating renewal of an existing certificate for crazyblockstech.com and www.crazyblockstech.com
http-01 challenge for crazyblockstech.com
http-01 challenge for www.crazyblockstech.com
Challenge failed for domain crazyblockstech.com
Challenge failed for domain www.crazyblockstech.com
   Domain: crazyblockstech.com
   Type:   unauthorized
   Detail: 198.199.89.17: Invalid response from
   http://crazyblockstech.com/.well-known/acme-challenge/VaeN0vIR3y83ZvdYtZPgW8A6hehL4fdEHFI1BvEQ9SE:
   403
   Domain: www.crazyblockstech.com
   Type:   unauthorized
   http://www.crazyblockstech.com/.well-known/acme-challenge/GJTc6_KhY6hjzSL_RguqbpZfnSmi5fseNG2z9pb4cxI:
   403
Debian 11 GNU/Linux x86-64
uname -a:
Linux debian-s-1vcpu-1gb-amd-nyc1-01 5.10.0-10-amd64 #1 SMP Debian 5.10.84-1 (2021-12-08) x86_64 GNU/Linux
DigitalOcean
debian-s-1vcpu-1gb-amd ("Premium AMD")
No
certbot 1.12.0
I am trying to renew my certificate for my website but running into this error when renewing.
Apache is used as a reverse proxy for Gunicorn in this case.
Thanks in advance.
Update: Disabled fail2ban but received the same error
Hi @CrazyblocksTech, and welcome to the LE community forum :slight_smile:
It's not a fail2ban issue.
Looks like Apache is up to some mischief.
Let's have a look at the output of:
apachectl -t -D DUMP_VHOSTS
Let's have a look at the output of: apachectl -t -D DUMP_VHOSTS
Output of apachectl -t -D DUMP_VHOSTS:
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443                  is a NameVirtualHost
         default server catchall (/etc/apache2/sites-enabled/crazyblockstech.com-le-ssl.conf:1)
         port 443 namevhost catchall (/etc/apache2/sites-enabled/crazyblockstech.com-le-ssl.conf:1)
         port 443 namevhost crazyblockstech.com (/etc/apache2/sites-enabled/crazyblockstech.com-le-ssl.conf:13)
                 alias www.crazyblockstech.com
*:80                   127.0.1.1 (/etc/apache2/sites-enabled/crazyblockstech.com.conf:12)
I ended up doing an reinstallation of Debian 11 (i.e. created new "Droplet" on DigitalOcean).
Redid the Apache and certbot configurations.
Now, verification succeeded after running certbot --apache -d crazyblockstech.com -d www.crazyblockstech.com
I am still unsure what happened with verification before but it was likely something to do with Apache.
