Renewal Delay - how long?
I just renewed my just expired domains, but they didn't seem to take effect. Not sure if it's my browser cache, but it's been half an hour now. How long of a delay I should expect before concluding that I did something wrong?
My domains are:
managedbycats.com
www.managedbycats.com
zombies.managedbycats.com
certbot certonly --manual -d managedbycats.com
...and the same for the other domains. They were successful.
The operating system my web server runs on is (include version): Ubuntu 20.04.1
My hosting provider, if applicable, is: A2Hosting
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no. just command line.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.40.0
Thank you! :slight_smile:
Hi @rmoffatt
that doesn't restart your webserver.
That's required.
Thank you, @JuergenAuer. I forgot to mention, I ran this after the renewals:
sudo apachectl restart
Just did it again to be sure :sweat_smile: Certs still not updated when I attempt to reach the domains.
The not working result is expected.
Checking https://managedbycats.com/ with my browser there is one certificate with all three domain names.
But you have created three certificates with one domain name. So the used certificate isn't replaced.
Create one certificate with 3 domain names.
Perfect. Thank you!
certbot certonly --manual -d managedbycats.com -d www.managedbycats.com -d zombies.managedbycats.com
-> Success.
Cheers!
