They should probably be applied - but not to fix this problem - just to be current
And if delete certbot-auto
, download newer certbot-auto
isn't the ideal solution...
Have you checked if AWS supports snap
Try:
snap version
Most likely it won't support it out of the box...
You could try adding snap
with something like:
[not sure which closest resembles AWS version]
But if you could get snap installed, then it's a SNAP from then on!
Thanks Sir! will try
Did you get it to 1.8.0 (manually) ?
nope, the 1.6.0 comes with a software and can“t find the way to update
Not "update" itself.
Do you remember how you downloaded/installed 1.6.0 ?
This is the point this cerbot comes packaged with a software. I“m trying to find it and delete it as you said
Huh?
Which software?
And (in this topic) you are only running certbot-auto
not certbot
[yes there is a difference]
Do you have both installed?
yes men, I“m runing certbot-auto
Ouch!
Certbot-auto is easy to replace.
just find it
find / -name certbot-auto
put the newer version on top of it [replace it]
