Renew does not work on Apache Tomcat (404)
Following problem:
With firewall we get invalid Port in redirect target. Without Firewall we can connect to /.well-known/acme-challange/test. The certbot-auto certonly command was running without the fierewall.
My domain is: itnn-db-test.de
I ran this command: certbot-auto certonly --webroot --webroot-path /usr/share/tomcat/webapps/ROOT -d itnn-db-test.de
Detail: Invalid response from
http://itnn-db-test.de/.well-known/acme-challenge/B0Q6ZE9Iwb8Yo-eCQTj5GXcaQgN7VczH41goCu20144
[178.254.33.168]: “\n\n404 Not
Found\n\n
Not Found
\n<p”
Apache Tomcat 7.0.76
Centos 7
1blu.de
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.40.1
Hi @mtheis
checking your domain there is a redirect to port 8443 - https://check-your-website.server-daten.de/?q=itnn-db-test.de
• http://itnn-db-test.de/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
178.254.33.168
302
	https://itnn-db-test.de:8443/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
	0.063
	A
Letsencrypt doesn't follow redirects to non-standard-ports. So that can't work. Remove that redirect, minimal, if the subdirectory starts with /.well-known/acme-challenge.
But curious: That error isn't visible, there is a http status 404 - Not Found visible.
Next curious thing:
answers with a Tomcat http status 404 - Not Found.
So first question: Is
correct?
Create the two required subdirectories
/usr/share/tomcat/webapps/ROOT/.well-known/acme-challenge
there a file (file name 1234), then try to load that file via
http://itnn-db-test.de/.well-known/acme-challenge/1234
That must work, if your webroot is correct.
