Renew certificate help
The certificate is expired, I renewed it but it’s still if I visit the site it says “Not secure” certificate is expired. I restarted the server but still same issue.
My domain is: private api
#sudo openssl x509 -in /etc/letsencrypt/live/api.example.net/cert.pem -text -noout
Validity
Not Before: Jan 31 14:31:17 2018 GMT
Not After : May 1 14:31:17 2018 GMT
#sudo netstat -ptan | grep LISTEN
tcp 0 0 127.0.0.1:27017 0.0.0.0:* LISTEN 962/mongod
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 971/sshd
tcp6 0 0 :::22 :::* LISTEN 971/sshd
My web server is (include version): nodjs
The operating system my web server runs on is (include version): ubuntu 14.04
My hosting provider, if applicable, is: AWS
tcp6 0 0 :::3000 :::* LISTEN 1834/node
tcp6 0 0 :::3001 :::* LISTEN 1834/node
tcp6 0 0 :::8443 :::* LISTEN 1834/node
Hi @thamerfa,
You can run certbot certificates to get a summary of all of the certificates that are installed and their expiration dates.
One possibility that comes to mind is that you might have specified a slightly different set of domain names in your certificate request when you obtained the original certificate and when you obtained the new certificate. In that case, one of them would be in /etc/letsencrypt/live/api.example.net-0001 or something similar to that because they would be managed as separate certificates. This has often confused users because they ended up with separate certificates without necessarily intending to, and of course their web server software was pointed at only one of the certificates.
Another possibility is that your web server is configured to point at something other than the auto-updated version in live; for example, if it’s pointed at the static version in archive, or at a copy that you made with cp, then it would still serve the old certificate even though a newer one is present.
Hi @schoen,
Thank you for your reply.
This is the certbot certificates result:
sudo ./certbot-auto certificates
Found the following certs:
Certificate Name: api.example.net
Domains: api.example.net
Expiry Date: 2018-05-01 14:31:17+00:00 (VALID: 87 days)
Certificate Path: /etc/letsencrypt/live/api.example.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/api.example.net/privkey.pem
I think it found only one certificate, and already checked the /etc/letsencrypt/live, only one folder exists.
Blockquote Another possibility is that your web server is configured to point at something other than the auto-updated version in live; for example, if it’s pointed at the static version in archive, or at a copy that you made with cp, then it would still serve the old certificate even though a newer one is present.
How can I make sure I'm not doing this?
Sometimes I got this error when run letsencrypt commands , not sure if it's related to the issue I'm having
Failed to find executable apache2ctl in PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
How did you install the certificate in your web server after you obtained it?
Do you also have a copy of Apache installed on this machine?
I don’t really remember how I installed the certificate, I followed some online tutorial. I’m not using apached. I use Nodejs with express.
Already fixed… was my mistake. I copied the certs manually on the folder and didn’t use the actual certs. Now all set. Thank you for trying to help.
