Removing a domain | Procedure for dehydrated
Dear team, I have this domain that I recently don't own anymore.
What would be the best procedure to disable its certificate? I use dehydrated to manage my domain certificates. Would a simpe removal from ./certs folder and the domains.txt be sufficient?
Thanks, Jos
Hello @joombler,
If you already have the cert, etc. you can revoke it using this command:
dehydrated --revoke path/to/cert.pem
But if your private key has not been compromised there is no need to revoke the certificate, simply delete the cert and key files and you are done.
Cheers,
sahsanu
There is no compromising involved.
Thank you for the service and keep up the good work.
BR, Jos
