I tried to remove an old godaddy issued certificate an use a new certbot certificate.
I edited the shoppercredit.com.conf file to remove the 443 section, then restarted apache and then ran the sudo letsencrypt --apache -d shoppercredit.com,www.shoppercredit.com to issue the certificates.
Everything seemd to work ok, but the site doesn’t provide a secure connection and won’t load.
I ran a test on ssllabs.com and it came back fine.
I’m assuming I’m missing a reference to the old certificates somewhere but I can’t find any references to it in the httpd.conf file or the ind virt server files.
Any insights appreciated.
- Jefffrey
My domain is: www.shoppercredit.com
I ran this command: sudo letsencrypt --apache -d shoppercredit.com,www.shoppercredit.com
It produced this output: executed successfully
My web server is (include version): Apache/2.4.6 (CentOS)
The operating system my web server runs on is (include version): CentOS Linux 7
Linux 4.17.17-x86_64-linode116 x86_64
My hosting provider, if applicable, is: Linode
