Removal of letsencrypt cert
PLEASE REVOKE THE LICENSES FOR : omingle.tv / www.omingle.tv
I would like to make new ones again.
My domain is: omingle.tv / www.omingle.tv
I ran this command: [ used some command for achme for caddy autossl ]
It produced this output: ssl was on for caddy but since i switched to nginx i removed the letsencrypt folder
My web server is (include version): debian 11
The operating system my web server runs on is (include version): debian 11
My hosting provider, if applicable, is: n/a
I can login to a root shell on my machine (yes or no, or I don't know): no
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): no, but using filezilla for file transfer
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): n/a
If that's the case, why would you revoke the previous certificates?
Usually, when the certificates and corresponding private keys are deleted, it's not necessary to revoke them per se.
i moved over to render.com and they issue the ssl certificates for my domain using letsencrypt. right now they are not being able to issue them because i already issued the certificates before on my end and since i dont have the certificates or anything in hand it would help revoking them and letting render issue them again instead.
nevermind, i just checked, it went through. sorry for the trouble and thanks a lot for the swift response!
You can issue multiple certificates for a hostname, even if you have gotten certs somewhere else. The only thing to make sure is that you haven't hit any rate limits.
Great! Have a good day :slight_smile:
got it, thanks alot!
you too!
