Remote VA DNS timeout for ChangeIP nameservers — all DNS-01 challenges fail on secondary validation
I am trying to add new and update existing domains and they are all failing the second validation layer. This is the most recent one i'm trying to add:
My domain is: dev2.passwordmap.com
I ran this command: certbot certonly --manual -d dev2.passwordmap.com --preferred-challenges dns
It produced this output: Requesting a certificate for dev2.passwordmap.com. Please deploy a DNS TXT record under the name: _acme-challenge.dev2.passwordmap.com. with the following value: G4p9aOhTEN_GfZe2s-CYmg6FqYWxhDbi5ihYBk2GZ0I. Before continuing, verify the TXT record has been deployed. Certbot failed to authenticate some domains (authenticator: manual). Domain: dev2.passwordmap.com. Type: dns. Detail: During secondary validation: DNS problem: query timed out looking up TXT for _acme-challenge.dev2.passwordmap.com. Hint: The Certificate Authority failed to verify the manually created DNS TXT records. Ensure that you created these in the correct location, or try waiting longer for DNS propagation on the next attempt.
My web server is (include version): Apache/2.4.66 (Amazon Linux) with mod_ssl
The operating system my web server runs on is (include version): Amazon Linux 2023
My hosting provider, if applicable, is: Self-hosted (Amazon EC2)
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.6.0
Sounds like something you need to speak with ChangeIP about.
Are those nameservers synchronizing quickly enough?
Are they blocking IPs/Networks?
I mean, yes you need working DNS servers in order to get a certificate, or for your domain to work at all. If you're not running your own DNS servers, you should contact whoever is.
I've hit the same secondary validation timeout with ChangeIP nameservers before, where the primary check passes but the remote validator can't resolve the TXT record. It turned out to be propagation lag between their nameservers rather than a misconfigured record. Waiting a few extra minutes and re-checking with a public resolver usually exposed the stale record.
Is there a reason you chose a DNS Challenge rather than HTTP? Because with Apache it should be relatively easy to get a cert using an HTTP Challenge. More importantly, it would allow automating the renewal of your certs. A --manual option will have to be repeated and as cert lifetimes get shorter it will have to be done more frequently. Automation should be your goal.
Let us know if you need help with an HTTP Challenge. You can use Certbot's --webroot, or possibly even its --Apache option. Or, consider Apache's built-in ACME Client called mod_md and you wouldn't need Certbot at all.
