Certbot renewal dns-01 challenge failure, During secondary validation: DNS problem
My domain is: https://dashboard.panorama9.com/
certbot certonly --dns-rfc2136 --dns-rfc2136-credentials -v
Certbot failed to authenticate some domains (authenticator: dns-rfc2136). The Certificate Authority reported these problems:
Domain: dashboard.panorama9.com
Type: dns
Detail: During secondary validation: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.dashboard.panorama9.com - check that a DNS record exists for this domain
The version of my client is certbot 1.21.0
we have two bind name servers ns1.panorama9.com and ns2.panorama9.com
while renewal is ongoing i can validate that the TXT record is there with dig, whether using our primary, secondary dns or the public google dns
dig @ns1.panorama9.com _acme-challenge.dashboard.panorama9.com TXT +short
but i get the output from above that the secondary validation failed
Is this related to Multi-Perspective Validation ? that some or multiple validation from some regions failed ?
I have used --dns-rfc2136-propagation-seconds to increase time up to 3 hours, i still get the same error.
Hi @ariah, and welcome to the LE community forum :slight_smile:
Probably (see secondary validation):
Thank you @rg305
right, it says NXDOMAIN, but when i dig the TXT record from any server i get NOERROR along side the value of the record. is the certficate authority querying some dns that have yet to be propoganded ? as i mentioned before, i did wait for 3 hours. And i can't think of anything on how to further debug this
Do you have the challenge token there at the moment? I'm currently seeing NXDOMAIN as well.
@petercooperjr it does now
"qrFzGWwfKPr5E1FrvOlr6n4BoQ5cUFEq6mMHqoVJ8d4"
Not from here
$ dig @ns1.panorama9.com _acme-challenge.dashboard.panorama9.com TXT +norecurse
; <<>> DiG 9.16.22-RH <<>> @ns1.panorama9.com _acme-challenge.dashboard.panorama9.com TXT +norecurse
; (1 server found)
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 59051
;; flags: qr aa; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 1
And I don't know if this is the root cause, but your DNS delegation isn't right either:
https://dnsviz.net/d/_acme-challenge.dashboard.panorama9.com/servers/
Warnings
  • com to panorama9.com: The following NS name(s) were found in the authoritative NS RRset, but not in the delegation NS RRset (i.e., in the com zone): ns2.panorama9.org, ns1.panorama9.org
  • com to panorama9.com: The following NS name(s) were found in the delegation NS RRset (i.e., in the com zone), but not in the authoritative NS RRset: ns1.panorama9.com, ns2.panorama9.com
That is, the .com zone says your nameservers end in .com:
$ dig -t NS panorama9.com. +norecurse @a.gtld-servers.net.
; <<>> DiG 9.16.22-RH <<>> -t NS panorama9.com. +norecurse @a.gtld-servers.net.
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 62877
;; flags: qr; QUERY: 1, ANSWER: 0, AUTHORITY: 2, ADDITIONAL: 3
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 4096
;; QUESTION SECTION:
;panorama9.com.                 IN      NS
;; AUTHORITY SECTION:
panorama9.com.          172800  IN      NS      ns1.panorama9.com.
panorama9.com.          172800  IN      NS      ns2.panorama9.com.
;; ADDITIONAL SECTION:
ns1.panorama9.com.      172800  IN      A       46.51.187.235
ns2.panorama9.com.      172800  IN      A       79.125.105.180
;; Query time: 0 msec
;; SERVER: 2001:503:a83e::2:30#53(2001:503:a83e::2:30)
;; WHEN: Tue Sep 13 17:19:00 UTC 2022
;; MSG SIZE  rcvd: 110
But, your nameserver says that they actually end in .org:
$ dig -t NS panorama9.com. +norecurse @46.51.187.235
; <<>> DiG 9.16.22-RH <<>> -t NS panorama9.com. +norecurse @46.51.187.235
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 34825
;; flags: qr aa; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 3
;; ANSWER SECTION:
panorama9.com.          3600    IN      NS      ns1.panorama9.org.
panorama9.com.          3600    IN      NS      ns2.panorama9.org.
ns1.panorama9.org.      1068    IN      A       46.51.187.235
ns2.panorama9.org.      1780    IN      A       79.125.105.180
;; Query time: 67 msec
;; SERVER: 46.51.187.235#53(46.51.187.235)
;; WHEN: Tue Sep 13 17:19:21 UTC 2022
;; MSG SIZE  rcvd: 123
I can't say either, but afaik, until recently the dns servers were helping validating tokens correctly, and there was no change there.
the .org servers are the one registered as NS on the hosting provider while .com are alias they both point to the same servers
this is more interesting, could it be geo related ? i've tried query on different laptops and i get the token correctly(can you please make the query again ? it'll be there for couple minutes)
I can't see it either. You can try this site. It uses similar method as Let's Encrypt server uses
https://unboundtest.com/
From a server in AWS's us-east-1 region:
[ec2-user@ip-172-31-59-142 ~]$ dig @46.51.187.235 _acme-challenge.dashboard.panorama9.com TXT +norecurse
; <<>> DiG 9.16.22-RH <<>> @46.51.187.235 _acme-challenge.dashboard.panorama9.com TXT +norecurse
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 3256
;_acme-challenge.dashboard.panorama9.com. IN TXT
panorama9.com.          3600    IN      SOA     ns1.panorama9.com. dns.jomax.net. 2016114767 28800 7200 604800 86400
;; WHEN: Tue Sep 13 17:21:18 UTC 2022
;; MSG SIZE  rcvd: 121
[ec2-user@ip-172-31-59-142 ~]$ dig @79.125.105.180 _acme-challenge.dashboard.panorama9.com TXT +norecurse
; <<>> DiG 9.16.22-RH <<>> @79.125.105.180 _acme-challenge.dashboard.panorama9.com TXT +norecurse
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 43328
;; SERVER: 79.125.105.180#53(79.125.105.180)
;; WHEN: Tue Sep 13 17:21:30 UTC 2022
From unboundtest, which uses a similar unbound configuration to that which Let's Encrypt uses (though I don't know what region it queries from):
https://unboundtest.com/m/TXT/_acme-challenge.dashboard.panorama9.com/NQOFTN56
Query results for TXT _acme-challenge.dashboard.panorama9.com
Response:
;; opcode: QUERY, status: NXDOMAIN, id: 11351
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 1, ADDITIONAL: 0
panorama9.com.	0	IN	SOA	ns1.panorama9.com. dns.jomax.net. 2016114767 28800 7200 604800 86400
All just saying NXDOMAIN. Are you sure you're updating the DNS servers that the outside world sees, and not some sort of visibly-internal-only server? Though the fact that you see a "secondary validation" message implies that the primary validation did see the record. Hmm…
yes, 79.125.105.180 and 46.51.187.235 are both aws bind servers registered as NS, and as you said the primary validation passed, but one or more of the validation from different regions didn't, which may mean that those dns weren't propagated with new records, hence why i did try to wait from 10 minutes to couple hours to no avail
I see
> $ nslookup
> > server ns1.panorama9.com
> Default server: ns1.panorama9.com
> Address: 46.51.187.235#53
> Server:         ns1.panorama9.com
> Address: 35.225.59.74
> > set q=soa
> *** Can't find dashboard.panorama9.com: No answer
> > panorama9.com
> panorama9.com
>         origin = ns1.panorama9.com
>         mail addr = dns.jomax.net
>         serial = 2016114818
>         refresh = 28800
>         retry = 7200
>         expire = 604800
>         minimum = 86400
And yet I do see the record when querying 1.1.1.1 (Cloudflare) or 8.8.8.8 (Google), even after their TTL expires, but I get NXDOMAIN via 64.6.64.6 (Verisign) or 208.67.222.222 (OpenDNS) (or when I try to check the authoritative servers myself).
So it does look like your DNS servers are giving different responses to different parts of the Internet, somehow.
And I see 2 different IP Addresses being used around the world
those are load balancers ip for the dashboard, in different regions: eu and us
So are you saying that your DNS server intentionally gives different answers for different regions for some queries? Because if that's the case, then definitely check that your TXT update is updating the responses for all regions.
Since Let's Encrypt use Multi-Perspective Validation Improves Domain Validation Security - Let's Encrypt
that's most likely it, let me check on this and get back to you, thanks for the breakthrough
Keep in mind that even though the problem seems to have started very recently, the root cause for it may have been implemented up to 60 days ago.
Sorry for late reply(just got access to the server)
So, yes that was it, we do have multiple zones, one for US regions, and the other zone for the rest, we were always updating the us one, and it was working file until recently(idk if Multi-Perspective Validation was implemented recently hence why validating from multiple regions ?)
Using certbot, is it possible to do the dns-challenge by adding the record simultaneously to the two zones ? or must we configure one zone to transfer data to the other ?
