Redirection loop okurs after certbot-auto
hi…
my setup:
LAMP server on Ubuntu 18.4
Serving Nextcloud 13
Dynamic DNS provider no-ip.com with my-domain.hopto.org
After certbot-auto install
wget https://dl.eff.org/certbot-auto
chmod a+x certbot-auto
sudo ./path/to/certbot-auto --apache
successful install and after installation I’ve some kind of redirection loop that redirects me to weird link https://my-domain.hopto.org/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud/nextcloud
have no clue whats wrong…
any ideas?
Thank you.
The redirect is in either the NextCloud config.php file or in the Apache config file for that site.
find / -name config.php
ls - l /etc/apache/sites-enabled/
So I have tried another couple times and have no luck… I moved from mydomai.hopto.org to mydomai.com and all works just fine… Only problem is that is on my home ISP with problem that IP could change in near future, so have to re-link it…
