My web server is (include version): Google cloud, Apache
The operating system my web server runs on is (include version): Debuan 9
My hosting provider, if applicable, is: Google cloud
I can login to a root shell on my machine (yes or no, or I don’t know): IDK
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): it was auto installed
please help i am a noobie in this sudo sudo thing. i ran this command in google cloud SSH terminal . Certbot autoinstalled everything and i am getting this redirect loop error. please tell me only SSH command to get this things done
this only happened after certbot, while installation it asked to whether to redirect all http to https, and i pressed yes. and all happened after that. now tried to reinstall it. but nothing is working.
can you please help me clearly where will i find that https ==> https loop. where to exactly edit. i am completely non technical
i renewed certbot certificate
The operating system my web server runs on is (include version): Apache
My hosting provider, if applicable, is: GOogle cloud
please help me, many people are facing the same issue, the automatic certbot installation has screwed up everything, many people have faced the same issue. please give me solution via SSH codes
