We getting the below error message while creating a certificate. This is occurring regularly. We are unable to provide certificates to customers. please look into it ASAP
root@84d448e12737:/# certbot certonly -n -d san1xxxxxx.com -d san1-d1.xxxxxx,san1-d2.xxxxxx.com --apache --agree-tos -m cloud@xxxxxx.com --noninteractive --dry-run
http-01 challenge for san1-d1.xxxx.com
http-01 challenge for san1-d2.xxxx.com
http-01 challenge for san1.xxxx.com
Enabled Apache rewrite module
An unexpected error occurred:
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 421, in _make_request
six.raise_from(e, None)
File "", line 3, in raise_from
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 416, in _make_request
httplib_response = conn.getresponse()
File "/usr/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/lib/python3.8/http/client.py", line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/lib/python3.8/socket.py", line 669, in readinto
return self._sock.recv_into(b)
File "/usr/lib/python3/dist-packages/urllib3/contrib/pyopenssl.py", line 326, in recv_into
raise timeout("The read operation timed out")
socket.timeout: The read operation timed out
File "/usr/lib/python3/dist-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 719, in urlopen
retries = retries.increment(
File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 400, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/lib/python3/dist-packages/six.py", line 703, in reraise
raise value
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 665, in urlopen
httplib_response = self._make_request(
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 423, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 330, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='acme-staging-v02.api.letsencrypt.org', port=443): Read timed out. (read timeout=45)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='acme-staging-v02.api.letsencrypt.org', port=443): Read timed out. (read timeout=45)
