My domain is: Many domains (Approx 200)
I ran this command: sudo certbot --nginx
261: www.xxx1.com
blank to select all options shown (Enter ‘c’ to cancel): ENTER
My web server is (include version): Nginx 1.12.0
The operating system my web server runs on is (include version):Ubuntu 16.04
Hello, I need some help.
After an update of certbot I received the following message in my log.
2017-07-21 00:59:23,957:DEBUG:certbot.main:certbot version: 0.14.2
2017-07-21 00:59:23,958:DEBUG:certbot.main:Arguments: []
2017-07-21 00:59:23,958:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#manual,PluginEntryPoint#nginx,PluginEntryPoint#null,PluginEntryPoint#standalone,PluginEntryPoint#webroot)
2017-07-21 00:59:23,993:DEBUG:certbot.plugins.selection:Requested authenticator <certbot.cli._Default object at 0x7facb69279d0> and installer <certbot.cli._Default object at 0x7facb69279d0>
2017-07-21 00:59:23,993:DEBUG:certbot.cli:Default Detector is Namespace(account=<certbot.cli._Default object at 0x7facb691dfd0>, agree_dev_preview=None, allow_subset_of_names=<certbot.cli._Default object at 0x7facb691dd90>, apache=<certbot.cli._Default object at 0x7facb69273d0>, apache_challenge_location=<certbot.cli._Default object at 0x7facb6990650>, apache_ctl=<certbot.cli._Default object at 0x7facb6996150>, apache_dismod=<certbot.cli._Default object at 0x7facb691d850>, apache_enmod=<certbot.cli._Default object at 0x7facb691d510>, apache_handle_modules=<certbot.cli._Default object at 0x7facb6990a50>, apache_handle_sites=<certbot.cli._Default object at 0x7facb6990e10>, apache_init_script=<certbot.cli._Default object at 0x7facb6996510>, apache_le_vhost_ext=<certbot.cli._Default object at 0x7facb6982190>, apache_logs_root=<certbot.cli._Default object at 0x7facb69829d0>, apache_server_root=<certbot.cli._Default object at 0x7facb6982050>, apache_vhost_root=<certbot.cli._Default object at 0x7facb69826d0>, authenticator=<certbot.cli._Default object at 0x7facb69279d0>, break_my_certs=<certbot.cli._Default object at 0x7facb6927c10>, cert_path=<certbot.cli._Default object at 0x7facb692ba10>, certname=<certbot.cli._Default object at 0x7facb6982490>, chain_path=<certbot.cli._Default object at 0x7facb692b410>, checkpoints=<certbot.cli._Default object at 0x7facb6933310>, config_dir=<certbot.cli._Default object at 0x7facb692b210>, config_file=None, configurator=<certbot.cli._Default object at 0x7facb69279d0>, csr=<certbot.cli._Default object at 0x7facb6933110>, debug=<certbot.cli._Default object at 0x7facb6927710>, debug_challenges=<certbot.cli._Default object at 0x7facb6927810>, dialog=None, domains=<certbot.cli._Default object at 0x7facb6982590>, dry_run=<certbot.cli._Default object at 0x7facb6982150>, duplicate=<certbot.cli._Default object at 0x7facb6927110>, eff_email=<certbot.cli._Default object at 0x7facb691d750>, email=<certbot.cli._Default object at 0x7facb691d8d0>, expand=<certbot.cli._Default object at 0x7facb691d2d0>, force_interactive=<certbot.cli._Default object at 0x7facb6982710>, fullchain_path=<certbot.cli._Default object at 0x7facb692b610>, func=<function certificates at 0x7facb6cd0410>, hsts=<certbot.cli._Default object at 0x7facb692b150>, http01_port=<certbot.cli._Default object at 0x7facb6927b10>, ifaces=<certbot.cli._Default object at 0x7facb692bdd0>, init=<certbot.cli._Default object at 0x7facb6933410>, installer=<certbot.cli._Default object at 0x7facb69279d0>, key_path=<certbot.cli._Default object at 0x7facb692b810>, logs_dir=<certbot.cli._Default object at 0x7facb6927dd0>, manual=<certbot.cli._Default object at 0x7facb691dd50>, manual_auth_hook=<certbot.cli._Default object at 0x7facb691d3d0>, manual_cleanup_hook=<certbot.cli._Default object at 0x7facb6996e10>, manual_public_ip_logging_ok=<certbot.cli._Default object at 0x7facb6933390>, must_staple=<certbot.cli._Default object at 0x7facb6927e10>, nginx=<certbot.cli._Default object at 0x7facb69271d0>, nginx_ctl=<certbot.cli._Default object at 0x7facb6933510>, nginx_server_root=<certbot.cli._Default object at 0x7facb6996990>, no_bootstrap=<certbot.cli._Default object at 0x7facb6927410>, no_self_upgrade=<certbot.cli._Default object at 0x7facb6927310>, no_verify_ssl=<certbot.cli._Default object at 0x7facb6927910>, noninteractive_mode=<certbot.cli._Default object at 0x7facb6982890>, num=<certbot.cli._Default object at 0x7facb692bed0>, os_packages_only=<certbot.cli._Default object at 0x7facb6927210>, post_hook=<certbot.cli._Default object at 0x7facb692ba50>, pre_hook=<certbot.cli._Default object at 0x7facb692b950>, pref_challs=<certbot.cli._Default object at 0x7facb692b850>, prepare=<certbot.cli._Default object at 0x7facb692bf90>, quiet=<certbot.cli._Default object at 0x7facb6927510>, reason=<certbot.cli._Default object at 0x7facb6933210>, redirect=<certbot.cli._Default object at 0x7facb6927f10>, register_unsafely_without_email=<certbot.cli._Default object at 0x7facb6982410>, reinstall=<certbot.cli._Default object at 0x7facb691d450>, renew_by_default=<certbot.cli._Default object at 0x7facb691d0d0>, renew_hook=<certbot.cli._Default object at 0x7facb692bb50>, renew_with_new_domains=<certbot.cli._Default object at 0x7facb691dc90>, rsa_key_size=<certbot.cli._Default object at 0x7facb6927d10>, server=<certbot.cli._Default object at 0x7facb6927bd0>, staging=<certbot.cli._Default object at 0x7facb6927610>, standalone=<certbot.cli._Default object at 0x7facb691df90>, standalone_supported_challenges=<certbot.cli._Default object at 0x7facb6933610>, staple=<certbot.cli._Default object at 0x7facb692b550>, strict_permissions=<certbot.cli._Default object at 0x7facb692b750>, text_mode=<certbot.cli._Default object at 0x7facb6982a10>, tls_sni_01_port=<certbot.cli._Default object at 0x7facb6927a10>, tos=<certbot.cli._Default object at 0x7facb691ded0>, uir=<certbot.cli._Default object at 0x7facb692b350>, update_registration=<certbot.cli._Default object at 0x7facb691da50>, user_agent=<certbot.cli._Default object at 0x7facb692bfd0>, validate_hooks=<certbot.cli._Default object at 0x7facb692bc50>, verb='certificates', verbose_count=<certbot.cli._Default object at 0x7facb6982b90>, webroot=<certbot.cli._Default object at 0x7facb691d090>, webroot_map=<certbot.cli._Default object at 0x7facb6933810>, webroot_path=<certbot.cli._Default object at 0x7facb69331d0>, work_dir=<certbot.cli._Default object at 0x7facb6927fd0>)
2017-07-21 00:59:24,064:DEBUG:certbot.log:Root logging level set at 20
2017-07-21 00:59:24,065:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2017-07-21 00:59:24,069:WARNING:certbot.storage:Attempting to parse the version 0.16.0 renewal configuration file found at /etc/letsencrypt/renewal/XXXXX1.com.br.conf with version 0.14.2 of Certbot. This might not work.
2017-07-21 00:59:24,070:WARNING:certbot.storage:Attempting to parse the version 0.15.0 renewal configuration file found at /etc/letsencrypt/renewal/XXXXX2.com.br.conf with version 0.14.2 of Certbot. This might not work.
2017-07-21 00:59:24,270:WARNING:certbot.storage: (… other messages identical to above about 30 other domains my …)
2017-07-21 00:59:24,810:DEBUG:certbot.ocsp:Querying OCSP for /etc/letsencrypt/live/XXXXX1.com.br/cert.pem
2017-07-21 00:59:24,811:DEBUG:certbot.ocsp:openssl ocsp -no_nonce -issuer /etc/letsencrypt/live/XXXXX1.com.br/chain.pem -cert /etc/letsencrypt/live/XXXXX1.com.br/cert.pem -url http://ocsp.int-x3.letsencrypt.org -CAfile /etc/letsencrypt/live/XXXXX1.com.br/chain.pem -verify_other /etc/letsencrypt/live/XXXXX1.com.br/chain.pem -trust_other -header Host ocsp.int-x3.letsencrypt.org
2017-07-21 00:59:25,058:DEBUG:certbot.ocsp:Querying OCSP for /etc/letsencrypt/live/XXXXX2.com.br/cert.pem
2017-07-21 00:59:25,059:DEBUG:certbot.ocsp:openssl ocsp -no_nonce -issuer /etc/letsencrypt/live/XXXXX2.com.br/chain.pem -cert /etc/letsencrypt/live/XXXXX2.com.br/cert.pem -url http://ocsp.int-x3.letsencrypt.org -CAfile /etc/letsencrypt/live/XXXXX2.com.br/chain.pem -verify_other /etc/letsencrypt/live/XXXXX2.com.br/chain.pem -trust_other -header Host ocsp.int-x3.letsencrypt.org
2017-07-21 00:59:25,159:DEBUG:certbot.ocsp:(… other messages identical to above about 30 other domains my …)
2017-07-21 00:59:31,473:ERROR:certbot.log:Exiting abnormally:
File “/usr/bin/letsencrypt”, line 11, in
load_entry_point(‘certbot==0.14.2’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 742, in main
File “/usr/lib/python2.7/dist-packages/certbot/main.py”, line 553, in certificates
cert_manager.certificates(config)
File “/usr/lib/python2.7/dist-packages/certbot/cert_manager.py”, line 84, in certificates
_describe_certs(config, parsed_certs, parse_failures)
File “/usr/lib/python2.7/dist-packages/certbot/cert_manager.py”, line 224, in _describe_certs
notify(_report_human_readable(config, parsed_certs))
File “/usr/lib/python2.7/dist-packages/certbot/cert_manager.py”, line 185, in _report_human_readable
if checker.ocsp_revoked(cert.cert, cert.chain):
File “/usr/lib/python2.7/dist-packages/certbot/ocsp.py”, line 64, in ocsp_revoked
output, err = util.run_script(cmd, log=logger.debug)
File “/usr/lib/python2.7/dist-packages/certbot/util.py”, line 82, in run_script
stdout, stderr = proc.communicate()
File “/usr/lib/python2.7/subprocess.py”, line 800, in communicate
return self._communicate(input)
File “/usr/lib/python2.7/subprocess.py”, line 1417, in _communicate
stdout, stderr = self._communicate_with_poll(input)
File “/usr/lib/python2.7/subprocess.py”, line 1471, in _communicate_with_poll
ready = poller.poll()
When I try to update these my domains, I received a failure and now I can not perform any actions (renew, new certificate), I get the following error.
“Error: urn:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new authz :: too many currently pending authorizations”
