Rate limited for duplicate certs for my load balancers - what to do?
Hi! Every time I provision new load balancers, if I provision more than 5, I get a rate limit error. I've tried keeping instances around longer, but sometimes things happen and I need more. (Also, every single time I try to get certs issued when I'm under load, the Let's Encrypt API is slow for me!) Right now every time I have this problem, I just leave the extra load balancers offline until a week later when their automatic renewal task fixes their cert, and then I add them into the mix at our CDN.
I wonder if I should get an override, or bite the bullet and add a key distribution mechanism?
acme-v02.api.letsencrypt.org
/certbot-auto certonly  -d acme-v02.api.letsencrypt.org \
  -d acme-v02-1.api.letsencrypt.org \
  -d acme-v02-2.api.letsencrypt.org \
  -d acme-v02-3.api.letsencrypt.org \
  -d acme-v02-4.api.letsencrypt.org \
  -d acme-v02-5.api.letsencrypt.org \
  -d incident.letsencrypt.org
There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains: acme-v02.api.letsencrypt.org acme-v02-1.api.letsencrypt.org acme-v02-2.api.letsencrypt.org acme-v02-3.api.letsencrypt.org acme-v02-4.api.letsencrypt.org acme-v02-5.api.letsencrypt.org incident.letsencrypt.org : see https://letsencrypt.org/docs/rate-limits/
nginx 1.21.6
n/a
no
1.25.0
Is he serious? Is this a test? Lemme see... What is his domain name?
Just curious :face_with_monocle:
ZeroSSL doesn't have rate limits on their production service. Have you given that a shot?
You probably just need to revoke all of your existing certificates to alleviate the load.
Just add dummy domain names to your certs!?!?!
Ah, when I spin down a load balancer, make sure to revoke the certs?
I think I have a way to do that real easy with a database query, can give this a try later
UPDATE certificateStatus SET status="revoked";
True. Be careful though. You want that command to be as broad as possible. "Inclusive", if you will.
Also, be certain of the protocol for your requests. You might need to bring your own sugar. If you see a 406 response, be cautious. If you get a 418 or, heaven forbid, a 2319, unplug your server as fast as possible and wait for things to cool down.
Please don't open threads with a log file almost a month old already. :wink:
April Fools!
clown-creepy-150x150
On an odd (and not joking note), I just got several minutes of non-response from https://acme-v02.api.letsencrypt.org and https://acme-v02.api.letsencrypt.org/directory. It appears to be resolved now. Was this deliberate or?
Why sure they are serious about April fools. :smile:
We did some traffic shifts today to reboot some hosts for updates, which shouldn't have been externally visible, but may have lead to what you saw. Do you have timestamps for when you saw this?
@mcpherrinm
Welcome to the party!
About 20 minutes into the creation of this topic. I visited both the base domain and /directory with my web browser and got "no data" responses for both.
That aligns with when the maintenance occurred. Thanks for the report, and I'll see if I can figure out where something went wrong.
Now you've got me curious which ACME client (and architecture for distributing certs) you actually use at your scale.
I prefer certbot-home myself when I'm not on the road. It has better support for HTCPCP.
