Need help for rate limit
My domain is: minumyukkaka.com
we got error rate limit when trying to renew certificate.
{"AffectedRows":0,"Message":"Fail to load resource from 'https://acme-v02.api.letsencrypt.org/acme/new-order'.\nurn:ietf:params:acme:error:rateLimited: Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: minumyukkaka.com,www.minumyukkaka.com, retry after 2024-02-22T03:11:50Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/","MessageKey":"","LocalizableMessage":"Fail to load resource from 'https://acme-v02.api.letsencrypt.org/acme/new-order'.\nurn:ietf:params:acme:error:rateLimited: Error creating new order :: too many certificates (5) already issued for this exact set of domains in the last 168 hours: minumyukkaka.com,www.minumyukkaka.com, retry after 2024-02-22T03:11:50Z: see https://letsencrypt.org/docs/duplicate-certificate-limit/","IsSuccess":false,"Action":"Batch","StatusCode":"BadRequest","Status":"failure","Properties":null}
We need to renew this one urgently because it is in production. Is any workaround or what to do for now.
Regards,
Handy
You have gotten one production cert nearly every day in the past week.
See crt.sh | minumyukkaka.com
Why can't you just use one of those?
Overrides are not possible for this rate limit. Please refer to below link for more details. You can see in the message you could try again after 2024-02-22 at T03:11:50 UTC
Or, try the work-around described below. But, you need to fix your system. You should not be requesting production certs every day. This rate limit is in place to protect Let's Encrypt from faulty systems just like yours.
It has been renewed:
Perhaps there is a problem with the ACME client [and how it saves the renewed certs, etc.]
Which ACME client are you using?
How do you renew the cert?
