Raspberrypi Wordpress Apache fix
not uninstall, run it:
certbot --apache
Wait there is an issue with port 80.
What does say:
apachectl -S
Hmmm? -
pi@raspberrypi:~ $ sudo certbot --apache
Error while running apache2ctl configtest.
Action 'configtest' failed.
apache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/sites-enabled/000-default.conf: /etc/apache2/sites-enabled/000-default.conf:1: <VirtualHost> was not closed.
The apache plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError("Error while running apache2ctl configtest.\nAction 'configtest' failed.\nThe Apache error log may have more information.\n\napache2: Syntax error on line 225 of /etc/apache2/apache2.conf: Syntax error on line 1 of /etc/apache2/sites-enabled/000-default.conf: /etc/apache2/sites-enabled/000-default.conf:1: <VirtualHost> was not closed.\n")
pi@raspberrypi:~ $
pi@raspberrypi:~ $
That file needs to be closed with an:
</VirtualHost>
So, I run that first…
Your nano edit ATE the last line of the 000-default.conf file.
Go back and ensure that file ends with a line “</VirtualHost>
[nano was hungry - lol]
Damned! I think it does?
<VirtualHost *:80>
    ServerName www.davidhallows.com
    ServerAlias davidhallows.com
    ServerAlias www.davidhallows.duckdns.org
    ServerAlias davidhallows.duckdns.org
    DocumentRoot /var/www/html
    LogLevel info
    Alias /.well-known/acme-challenge/ /var/www/html
    Redirect / https://www.davidhallows.com
</VirtualHost>
add an extra carriage return / line feed / blank line at the end [just to be sure]
or # line
like:
<VirtualHost *:80>
    LogLevel info
</VirtualHost>
I’m in! Shall I choose them all?
Yes ALL on one cert.
WAIT
One doesn’t resolve via DNS.
So, 2 3 and 4? …
See post #34
You should add that to your DNS zone.
Same place you added the CNAME.
Oh darn, you can't CNAME the base domain - not without trashing all other entries.
Disregard the "davidhallows.com" name from the list.
Choose the other 3 names.
I can't see your screen...
ebian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Mon Nov 18 16:46:56 2019
1: davidhallows.com
2: www.davidhallows.com
3: davidhallows.duckdns.org
4: www.davidhallows.duckdns.org
1 won’t work.
use 2,3,4
ok, expand?
requested (ref: /etc/letsencrypt/renewal/www.davidhallows.com.conf)
It contains these names: www.davidhallows.com, www.davidhallows.duckdns.org
You requested these names for the new certificate: www.davidhallows.com,
davidhallows.duckdns.org, www.davidhallows.duckdns.org.
certificate?
(E)xpand/(C)ancel:
Ok, I’ve expanded it …
new sites, or if you're confident your site works on HTTPS. You can undo this
change by editing your web server's configuration.
Select the appropriate number [1-2] then [enter] (press 'c' to cancel):
Presumably it’s no 2???! :slight_smile:
1 we already have a redirection statement
Done! Unfortunately my better half need my machine for a presentation gig. Worst timing!!! Thanks sooooooooooooooooooooooo mch for all yor help. I’ll catch up later :slight_smile:
Happy wife = happy life !
[need to find a rhyme for spouse… mouse… house…]
