But that leaves us with nothing in the sites-enabled folder…
I don’t know how your site is working.
Let’s begin at the beginning.
Please show:
/etc/apache2/apache2.conf
Here’s the copy from apache2.conf -
This is the main Apache server configuration file. It contains the
configuration directives that give the server its instructions.
See http://httpd.apache.org/docs/2.4/ for detailed information about
the directives and /usr/share/doc/apache2/README.Debian about Debian specific
hints.
Summary of how the Apache 2 configuration works in Debian:
The Apache 2 web server configuration in Debian is quite different to
upstream’s suggested way to configure the web server. This is because Debian’s
default Apache2 installation attempts to make adding and removing modules,
virtual hosts, and extra configuration directives as flexible as possible, in
order to make automating the changes and administering the server as easy as
possible.
It is split into several files forming the configuration hierarchy outlined
below, all located in the /etc/apache2/ directory:
/etc/apache2/
|-- apache2.conf
| `-- ports.conf
|-- mods-enabled
| |-- *.load
| `-- *.conf
|-- conf-enabled
| `-- *.conf
`-- sites-enabled
`-- *.conf
* apache2.conf is the main configuration file (this file). It puts the pieces
together by including all remaining configuration files when starting up the
web server.
* ports.conf is always included from the main configuration file. It is
supposed to determine listening ports for incoming connections which can be
customized anytime.
* Configuration files in the mods-enabled/, conf-enabled/ and sites-enabled/
directories contain particular configuration snippets which manage modules,
global configuration fragments, or virtual host configurations,
respectively.
They are activated by symlinking available configuration files from their
respective *-available/ counterparts. These should be managed by using our
helpers a2enmod/a2dismod, a2ensite/a2dissite and a2enconf/a2disconf. See
their respective man pages for detailed information.
* The binary is called apache2. Due to the use of environment variables, in
the default configuration, apache2 needs to be started/stopped with
/etc/init.d/apache2 or apache2ctl. Calling /usr/bin/apache2 directly will not
work with the default configuration.
Global configuration
ServerRoot: The top of the directory tree under which the server’s
configuration, error, and log files are kept.
NOTE! If you intend to place this on an NFS (or otherwise network)
mounted filesystem then please read the Mutex documentation (available
at URL:http://httpd.apache.org/docs/2.4/mod/core.html#mutex);
you will save yourself a lot of trouble.
Do NOT add a slash at the end of the directory path.
#ServerRoot “/etc/apache2”
The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
#Mutex file:${APACHE_LOCK_DIR} default
The directory where shm and other runtime files will be stored.
DefaultRuntimeDir ${APACHE_RUN_DIR}
PidFile: The file in which the server should record its process
identification number when it starts.
This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
Timeout: The number of seconds before receives and sends time out.
Timeout 300
KeepAlive: Whether or not to allow persistent connections (more than
one request per connection). Set to “Off” to deactivate.
KeepAlive On
MaxKeepAliveRequests: The maximum number of requests to allow
during a persistent connection. Set to 0 to allow an unlimited amount.
We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
KeepAliveTimeout: Number of seconds to wait for the next request from the
same client on the same connection.
KeepAliveTimeout 5
These need to be set in /etc/apache2/envvars
User {APACHE_RUN_USER} Group {APACHE_RUN_GROUP}
HostnameLookups: Log the names of clients or just their IP addresses
e.g., www.apache.org (on) or 204.62.129.132 (off).
The default is off because it’d be overall better for the net if people
had to knowingly turn this feature on, since enabling it means that
each client request will result in AT LEAST one lookup request to the
nameserver.
HostnameLookups Off
ErrorLog: The location of the error log file.
If you do not specify an ErrorLog directive within a
container, error messages relating to that virtual host will be
logged here. If you do define an error logfile for a
container, that host’s errors will be logged there and not here.
LogLevel: Control the severity of messages logged to the error_log.
Available values: trace8, …, trace1, debug, info, notice, warn,
error, crit, alert, emerg.
It is also possible to configure the log level for particular modules, e.g.
“LogLevel info ssl:warn”
LogLevel warn
Include module configuration:
IncludeOptional mods-enabled/.load
IncludeOptional mods-enabled/.conf
Include list of ports to listen on
Include ports.conf
Sets the default security model of the Apache2 HTTPD server. It does
not allow access to the root filesystem outside of /usr/share and /var/www.
The former is used by web applications packaged in Debian,
the latter may be used for local directories served by the web server. If
your system is serving content from a sub-directory in /srv you must allow
access here, or in any related virtual host.
Options FollowSymLinks AllowOverride None Require all denied<Directory /usr/share>
AllowOverride None
Require all granted
<Directory /var/www/>
AllowOverride All
Require all granted
#<Directory /srv/>
AllowOverride None
Require all granted
AccessFileName: The name of the file to look for in each directory
for additional configuration directives. See also the AllowOverride
directive.
AccessFileName .htaccess
The following lines prevent .htaccess and .htpasswd files from being
viewed by Web clients.
<FilesMatch “^.ht”>
Require all denied
The following directives define some format nicknames for use with
a CustomLog directive.
These deviate from the Common Log Format definitions in that they use %O
(the actual bytes sent including headers) instead of %b (the size of the
requested file), because the latter makes it impossible to detect partial
requests.
Note that the use of %{X-Forwarded-For}i instead of %h is not recommended.
Use mod_remoteip instead.
LogFormat “%v:%p %h %l %u %t “%r” %>s %O “%{Referer}i” “%{User-Agent}i”” vhost_combined
LogFormat “%h %l %u %t “%r” %>s %O “%{Referer}i” “%{User-Agent}i”” combined
LogFormat “%h %l %u %t “%r” %>s %O” common
LogFormat “%{Referer}i -> %U” referer
LogFormat “%{User-agent}i” agent
Include of directories ignores editors’ and dpkg’s backup files,
see README.Debian for details.
Include generic snippets of statements
IncludeOptional conf-enabled/*.conf
Include the virtual host configurations:
IncludeOptional sites-enabled/*.conf
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Please edit that last post and add at the top and bottom on separate lines (three tilde - back ticks):
[So that it makes it legible.]
Thanks rg305! It did look ridiculous
# This is the main Apache server configuration file. It contains the
# configuration directives that give the server its instructions.
# See http://httpd.apache.org/docs/2.4/ for detailed information about
# the directives and /usr/share/doc/apache2/README.Debian about Debian specific
# hints.
# Summary of how the Apache 2 configuration works in Debian:
# The Apache 2 web server configuration in Debian is quite different to
# upstream’s suggested way to configure the web server. This is because Debian’s
# default Apache2 installation attempts to make adding and removing modules,
# virtual hosts, and extra configuration directives as flexible as possible, in
# order to make automating the changes and administering the server as easy as
# possible.
# It is split into several files forming the configuration hierarchy outlined
# below, all located in the /etc/apache2/ directory:
# /etc/apache2/
# |-- apache2.conf
# | `-- ports.conf
# |-- mods-enabled
# | |-- *.load
# | `-- *.conf
# |-- conf-enabled
# | `-- *.conf
# `-- sites-enabled
# `-- *.conf
# * apache2.conf is the main configuration file (this file). It puts the pieces
# together by including all remaining configuration files when starting up the
# web server.
# * ports.conf is always included from the main configuration file. It is
# supposed to determine listening ports for incoming connections which can be
# customized anytime.
# * Configuration files in the mods-enabled/, conf-enabled/ and sites-enabled/
# directories contain particular configuration snippets which manage modules,
# global configuration fragments, or virtual host configurations,
# respectively.
# They are activated by symlinking available configuration files from their
# respective *-available/ counterparts. These should be managed by using our
# helpers a2enmod/a2dismod, a2ensite/a2dissite and a2enconf/a2disconf. See
# their respective man pages for detailed information.
# * The binary is called apache2. Due to the use of environment variables, in
# the default configuration, apache2 needs to be started/stopped with
# /etc/init.d/apache2 or apache2ctl. Calling /usr/bin/apache2 directly will not
# work with the default configuration.
# Global configuration
# ServerRoot: The top of the directory tree under which the server’s
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the Mutex documentation (available
# at URL:http://httpd.apache.org/docs/2.4/mod/core.html#mutex);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
# The directory where shm and other runtime files will be stored.
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to “Off” to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 5
# These need to be set in /etc/apache2/envvars
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., [www.apache.org](http://www.apache.org/) (on) or 204.62.129.132 (off).
# The default is off because it’d be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# ErrorLog: The location of the error log file.
# If you do not specify an ErrorLog directive within a
# container, error messages relating to that virtual host will be
# logged here. If you *do* define an error logfile for a
# container, that host’s errors will be logged there and not here.
# LogLevel: Control the severity of messages logged to the error_log.
# Available values: trace8, …, trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the log level for particular modules, e.g.
# “LogLevel info ssl:warn”
LogLevel warn
# Include module configuration:
IncludeOptional mods-enabled/ <em>.load
IncludeOptional mods-enabled/</em> .conf
# Include list of ports to listen on
Include ports.conf
# Sets the default security model of the Apache2 HTTPD server. It does
# not allow access to the root filesystem outside of /usr/share and /var/www.
# The former is used by web applications packaged in Debian,
# the latter may be used for local directories served by the web server. If
# your system is serving content from a sub-directory in /srv you must allow
# access here, or in any related virtual host.
AllowOverride None
Require all granted
AllowOverride All
Require all granted
#<Directory /srv/>
# Options Indexes FollowSymLinks
# AllowOverride None
# Require all granted
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch “^.ht”>
Require all denied
# The following directives define some format nicknames for use with
# a CustomLog directive.
# These deviate from the Common Log Format definitions in that they use %O
# (the actual bytes sent including headers) instead of %b (the size of the
# requested file), because the latter makes it impossible to detect partial
# requests.
# Note that the use of %{X-Forwarded-For}i instead of %h is not recommended.
# Use mod_remoteip instead.
# Include of directories ignores editors’ and dpkg’s backup files,
# see README.Debian for details.
# Include generic snippets of statements
# Include the virtual host configurations:
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Nothing mysterious there...
Let's move to the next set of files:
Please show:
ls -l /etc/apache2/sites-enabled/*.conf
Ok, cheers again. Here it is…
pi@raspberrypi:~ $ ls -l /etc/apache2/sites-enabled/*.conf
lrwxrwxrwx 1 root root 35 Nov 16 10:15 /etc/apache2/sites-enabled/000-default.conf -> ../sites-available/000-default.conf
pi@raspberrypi:~ $
pi@raspberrypi:~ $
Ok; perfect, only one file.
Let’s see that file:
[you can probably go back and delete post #22 - with the garbled text]
On second though, that file may not exist.
If not, please create it (in the sites-available folder)
here is a sample default file:
<VirtualHost *:80>
# specifies what hostname must appear in the request's Host: header to
#ServerName www.example.com
DocumentRoot /var/www/html
# modules, e.g.
#LogLevel info ssl:warn
</VirtualHost>
Which can be reduced (removing all the noise) to just:
<VirtualHost *:80>
</VirtualHost>
From there we can customize it to your needs.
Ok, brill -
pi@raspberrypi:~ $ sudo nano /etc/apache2/sites-enabled/000-default.conf
GNU nano 3.2 /etc/apache2/sites-enabled/000-default.conf Modified
/etc/apache2/sites-enabled/000-default.conf<VirtualHost *:80>
# port that the server uses to identify itself. This is used
# when creating redirection URLs. In the context of virtual
# hosts, the ServerName specifies what hostname must appear in
# the request's Host: header to match this virtual host. For the
# default virtual host (this file) this value is not decisive as
# it is used as a last resort host regardless. However, you must
# set it for any further virtual host explicitly.
# modules, e.g.
I can’t see all of it but it should be pretty vanilla.
Let’s make that to better suite your need:
<VirtualHost *:80>
ServerName www.davidhallows.com
ServerAlias davidhallows.com
ServerAlias www.davidhallows.duckdns.org
ServerAlias davidhallows.duckdns.org
LogLevel info
Alias /.well-known/acme-challenge/ /var/www/html
Redirect / https://www.davidhallows.com
</VirtualHost>
Sorry, here’s the full copy…
</VirtualHost>
Gut that out (full remodel) and replace it with content above.
Oh, I see that was the same as the last reply. So, should I copy in your response at the bottom?
Ok
I’ll do it now and let yo know
Whilst we wait…
Here is some DNS stuff you might want to address (later):
www.davidhallows.com > davidhallows.duckdns.org > 92.30.233.43 [GOOD]
davidhallows.com > [NOTHING/NOWHERE - NOT SO GOOD]
www.davidhallows.duckdns.org > 92.30.233.43 [GOOD]
JustHost isn’t doing aa great job at DNS resiliency:
[you might want to add some free secondary DNS servers]
It all seems to have dropped off…?
I don’t know much about nano, is that where you are having trouble?
[ I use vi ]
No, mean the links don’t connect now -
This site can’t be reached
www.davidhallows.com refused to connect.
Try:
- Checking the connection
- Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
Same as my internal ip in the browser.
We’ll we got ahead of ourselves.
There is a redirect to HTTPS - but that’s not in place yet.
You need to run certbot and get a cert.
Ok, do I need to uninstall the current certbot too?
