Ssl_module used in ports.conf but does not exist
My domain is uroflowabara.ddns.net
everything looks like it worked.
It produced this output:This site can’t be reacheduroflowabara.ddns.net refused to connect.
Try:
Checking the connection
Checking the proxy and the firewall
ERR_CONNECTION_REFUSED
My web server is (include version): Apache2
The operating system my web server runs on is (include version):debian 10
My hosting provider, if applicable, is: (on a raspi)
I see that in the Virtual Hosts and in ports_conf there are
Listen 443
I do not have this ssl_module installed?
Could this be why it does not work?
Hi @jbrohan,
Welcome to the community forum!
You’ll need to enable the SSL module for Apache. You can check what modules are available by running:
$ echo | a2enmod | grep -i ssl
To actually enable it, run:
$ sudo a2enmod ssl
Hi Phil
Thank you so much for your kind reply.
a2enmod ssl says it’s already running.
I’m getting “the site can’t be reached” when I run it as https
My plan was to go through the apache2.conf step by step making sure that each configuration file does its “thing”
/etc/apache2/ports.conf
Listen 80
    Listen 443
    Listen 443
This looks to me as though port 443 is not setup for Listening if ssl_module isn’t there or the gnutils.c
I’m on a raspberry pi under debian buster, and I followed the Let’s Encrypt as carefully as I could.
http://uroflowabara.ddns.net works fine (brings up the debian Apache welcome page.
https://uroflowabara.ddns.net gives me “this site can’t be reached”
I am so impressed with Let’s Encrypt, I’m sure it’s just a simple thing.
Do you know of a checklist I can go through to ensure that my one site works properly.
@jbrohan,
Can you run apache2ctl -S and also paste each of your vhost configurations please?
Thanks Phil.
I still have my suspicions of “” which seems to control the https port. It’s in /etc/apache2/ports.conf !!?
Thank you so much for your help. A kind and knowledgeable word is welcome in this stressful time.
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.1.1. Set the ‘ServerName’ directive globally to suppress this message
VirtualHost configuration:
*:443 uroflowcanada.ddns.net (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 127.0.1.1 (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: “/etc/apache2”
Main DocumentRoot: “/var/www/html”
Main ErrorLog: “/var/log/apache2/error.log”
PidFile: “/var/run/apache2/apache2.pid”
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name=“www-data” id=33
Group: name=“www-data” id=33
Virtual Hosts (443)
sudo cat /etc/apache2/sites-enabled/000-default-le-ssl.conf
<VirtualHost *:443>
The ServerName directive sets the request scheme, hostname and port that
the server uses to identify itself. This is used when creating
redirection URLs. In the context of virtual hosts, the ServerName
specifies what hostname must appear in the request’s Host: header to
match this virtual host. For the default virtual host (this file) this
value is not decisive as it is used as a last resort host regardless.
However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
DocumentRoot /var/www/html
Available loglevels: trace8, …, trace1, debug, info, notice, warn,
error, crit, alert, emerg.
It is also possible to configure the loglevel for particular
modules, e.g.
#LogLevel info ssl:warn
For most configuration files from conf-available/, which are
enabled or disabled at a global level, it is possible to
include a line for only one particular virtual host. For example the
following line enables the CGI configuration for this host only
after it has been globally disabled with “a2disconf”.
ServerName uroflowcanada.ddns.net
SSLCertificateFile /etc/letsencrypt/live/uroflowcanada.ddns.net/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/uroflowcanada.ddns.net/privkey.pem
Virtual hosts (80)
urouser@raspberrypi : ~ $ sudo cat /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
modules, e.g.
RewriteEngine on
RewriteCond %{SERVER_NAME} =uroflowcanada.ddns.net
vim: syntax=apache ts=4 sw=4 sts=4 sr noet
Hi Phil
Thanks for your quick reply. I am learning more about this elegant piece of software which runs major websites as well as my tiny server on a raspberryPi. I am sure I’m near to getting SSL working, and your help is Most welcome.
John
urouser@raspberrypi:~ $ sudo apache2ctl -S
[sudo] password for urouser:
Define: DUMP_VHOSTS
Virtual host 443
urouser@raspberrypi:~ $ sudo cat /etc/apache2/sites-enabled/000-default-le-ssl.conf
<VirtualHost *:443>
# specifies what hostname must appear in the request's Host: header to
#ServerName [www.example.com](http://www.example.com)
# error, crit, alert, emerg.
# modules, e.g.
Virtual host 80
urouser@raspberrypi:~ $ sudo cat /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
# modules, e.g.
RewriteEngine on
Hi Phil
On “check your website” I find that there are 2 errors.
I made a certificate for uroflowabara.ddns.net before I found out about LetsEncrypt. Should I abandon this and try another domain?
Hi @jbrohan
different Serial numbers are not good. But that's
  • a name server problem, not a domain problem
  • if the A / AAAA / CAA / TXT records identical, it's not a problem
So it's not really a problem that blocks creating a Letsencrypt certificate (same with Html-Content problems etc.).
Hi Juergen
Thank you for your kind reply. I am very interested to get this LetsEncrypt working. Can I summarize my status and show some .conf files?
I’m trying to install uroflowmain.ddns.net on LAMP on a raspberrypi.
http:uroflowmain.ddns.net/test.php works fine (shows my test.php output)
https://uroflowmain.ddns.net/test.php on chrome gives me
"This site can’t be [reacheduroflowmain.ddns.net](http://reacheduroflowmain.ddns.net) refused to connect.
ERR_CONNECTION_REFUSED"
I also have uroflowabara.ddns.net and uroflowcanada.ddns.net
me urouser@raspberrypi:~ $ **sudo apache2ctl -S**
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
*:443                  is a NameVirtualHost
         default server [uroflowcanada.ddns.net](http://uroflowcanada.ddns.net) (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
         port 443 namevhost [uroflowcanada.ddns.net](http://uroflowcanada.ddns.net) (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
                 alias [uroflowabara.ddns.net](http://uroflowabara.ddns.net)
                 alias [uroflowmain.ddns.net](http://uroflowmain.ddns.net)
         port 443 namevhost 127.0.1.1 (/etc/apache2/sites-enabled/default-ssl.conf:2)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
> User: name="www-data" id=33
Group: name="www-data" id=33
urouser@raspberrypi:~ $ **sudo cat /etc/apache2/ports.conf**
# If you just change the port or add more ports here, you will likely also
# have to change the VirtualHost statement in
# /etc/apache2/sites-enabled/000-default.conf
Listen 80
<IfModule ssl_module>
	Listen 443
</IfModule>
<IfModule mod_gnutls.c>
	Listen 443
</IfModule>
# vim: syntax=apache ts=4 sw=4 sts=4 sr noet
note I've commented out teh rewrite rule hoping that it will not redirect http-> https.
**urouser@raspberrypi**:**~ $** sudo **cat /etc/apache2/sites-enabled/000-default.conf**
<VirtualHost *:80>
	# modules, e.g.
#RewriteEngine on
#RewriteCond %{SERVER_NAME} =[uroflowcanada.ddns.net](http://uroflowcanada.ddns.net)
#RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,NE,R=permanent]
</VirtualHost>
**urouser@raspberrypi**:**~ $** **sudo cat /etc/apache2/sites-enabled/000-default-le-ssl.conf**
<IfModule mod_ssl.c>
<VirtualHost *:443>
	# modules, e.g.
ServerName [uroflowcanada.ddns.net](http://uroflowcanada.ddns.net)
ServerAlias [uroflowabara.ddns.net](http://uroflowabara.ddns.net)
ServerAlias [uroflowmain.ddns.net](http://uroflowmain.ddns.net)
SSLCertificateFile /etc/letsencrypt/live/[uroflowabara.ddns.net/fullchain.pem](http://uroflowabara.ddns.net/fullchain.pem)
SSLCertificateKeyFile /etc/letsencrypt/live/[uroflowabara.ddns.net/privkey.pem](http://uroflowabara.ddns.net/privkey.pem)
</VirtualHost>
</IfModule>
Why is there a duplicated definition?
Your port 443 vHost looks like you have created that manual. Let Certbot do that job. And why is ServerName / ServerAlias splittet?
Checking https://uroflowmain.ddns.net/test.php I see a timeout, not a connection refused.
Hi Juergen
I am using a https://www.noip.com/ dynamic hostname service. I made three hostnames to try and get one of them to work!
Listen 443 Listen 443
That's the way it comes from apt-get install apache2 on a raspberrypi. Can I just delete the <IfModule and leave "Listen 443" ?
I would LOVE to let Certbot do it all, but it didn't. After the run of Certbot the HttpS version of my site gave connection refused! It gave me connection_refused. So I commented out the redirect in the vhosts for port 80 thinking that a syntax error might be causing the problem.
Is there any way I can just remove all my bumbling and start again with certbot. I did go out and buy a new SD card and re-installed everything, but it still clogs here.
In debugging a normal program we put comments in to find out where it is crashing, so we can go step by step and find the error. Is there any way to do this with apache configuration?
I appreciate very much the goals and energy that you all are putting into Letsencrypt. I want very much to get it working and then perhaps help others to secure their websites.
Thank you very much
John
Checking [https://uroflowmain.ddns.net/test.php](https://uroflowmain.ddns.net/test.php) I see a timeout, not a connection refused.
still connection refused here in Chrome on a Mac.
Thank you again for a kind voice out of the mysterious world of web servers!
Yours Sincerely
John
Here is the apache2ctl -S output and the 2 virtual hosts files... 80 is fine 443 gets refused.
**urouser@raspberrypi:~ $ sudo cat /etc/apache2/sites-enabled/000-default-le-ssl.conf**
<VirtualHost *:443>
	# modules, e.g.
</VirtualHost>
</IfModule>
<VirtualHost *:443>
	# modules, e.g.
</VirtualHost>
</IfModule>
@jbrohan,
First we’ll check DNS for your domains (looks good).
$ dig uroflowmain.ddns.net +short
74.59.228.16
$ dig uroflowcanada.ddns.net +short
74.59.228.16
$ dig uroflowabara.ddns.net +short
74.59.228.16
Next we’ll take a look at the open ports on your machine. Apache isn’t currently binding to port 443, or it just may not be opened in your firewall. We’ll troubleshoot this below the code snippet.
$ nmap -T4 -A 74.59.228.16
Starting Nmap 7.70 ( https://nmap.org ) at 2019-11-14 13:51 EST
Stats: 0:00:24 elapsed; 0 hosts completed (1 up), 1 undergoing Service Scan
Service scan Timing: About 50.00% done; ETC: 13:52 (0:00:16 remaining)
Nmap scan report for modemcable016.228-59-74.mc.videotron.ca (74.59.228.16)
Host is up (0.055s latency).
Not shown: 996 filtered ports
PORT     STATE  SERVICE    VERSION
53/tcp   open   domain     (generic dns response: NOTIMP)
| fingerprint-strings:
|   DNSVersionBindReqTCP:
|     version
|_    bind
80/tcp   open   http       Apache httpd 2.4.38 ((Raspbian))
|_http-server-header: Apache/2.4.38 (Raspbian)
|_http-title: Apache2 Debian Default Page: It works
81/tcp   closed hosts2-ns
8080/tcp closed http-proxy
1 service unrecognized despite returning data. If you know the service/version, please submit the following fingerprint at https://nmap.org/cgi-bin/submit.cgi?new-service :
SF-Port53-TCP:V=7.70%I=7%D=11/14%Time=5DCDA251%P=x86_64-redhat-linux-gnu%r
SF:(DNSVersionBindReqTCP,20,"\0\x1e\0\x06\x81\x85\0\x01\0\0\0\0\0\0\x07ver
SF:sion\x04bind\0\0\x10\0\x03")%r(DNSStatusRequestTCP,E,"\0\x0c\0\0\x90\x0
SF:4\0\0\0\0\0\0\0\0");
What’s the output of the following commands?
sudo netstat -plunt | egrep '(80|443)'
sudo iptables -nL
Next let’s look at your apache vhosts. Back up your vhost configurations and then can you test using these updated vhost configurations please? Remember to restart/reload apache after making the change.
HTTP vhost: /etc/apache2/sites-enabled/000-default.conf
<VirtualHost *:80>
    ServerAlias uroflowabara.ddns.net uroflowmain.ddns.net
	# modules, e.g.
    RewriteEngine on
    RewriteCond %{HTTPS} off
    RewriteRule ^(.*)$ https://%{HTTP_HOST}%{REQUEST_URI}
</VirtualHost>
HTTPS vhost: /etc/apache2/sites-enabled/000-default-le-ssl.conf
<VirtualHost *:443>
	# modules, e.g.
    SSLCertificateFile /etc/letsencrypt/live/uroflowabara.ddns.net/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/uroflowabara.ddns.net/privkey.pem
</VirtualHost>
On your own command line, can you run curl -vIL http://localhost and curl -vIL https://localhost and paste that output? This will verify that you can at least hit the HTTPS vhost internally on your raspberry pi.
Hi Phil
Thanks for your kind replies. Here is a summary of current status.
I reinstalled Apache and Certbot.
My Domain name is uroflowcanada.ddns.net from NOIP. Itis a dynamic dns expected to run on a Raspberry Pi connected to a regular wifi port in a house or office setting
The HTTP http://uroflowcanada.ddns.net url works exactly correctly
The HTTPS https://uroflowcanada.ddns.net fails with ERR_CONNECTION_REFUSED
I am sorry there is so much ‘stuff’ I’ve included as much as I can in the hopes that the magic line will pop out to your experienced eye.
My opinion.
I don’t think it’s getting very far into the system when it’s HTTPS. The rejection comes quickly, before it can be logged in /var/apache2/error.log. It’s likely some necessary component that is not loaded. I an logging at trace8 level, but it does not seem to be working for even http.
Thank you so much. I’ll keep an eye on the forum page as well as the email.
I cut out some boring parts of the output to get it below 32K.
Yours Sincerely
John
Included here are .
Error logs with LogLevel : trace8
The error log indicates a problem with mod_md
The logs indicate only that the apache2 started and it found certificates for 443 https://uroflowcanada.ddns.net
sudo apache2ctl -S
Looks good.
Listing of the sites-available virtual hosts on this machine.
To my unpracticed eye this looks OK too.
dig output -> 74.59.228.16
if you search for the bold words like dig, you'll find the output.
nmap printout is voluminous and lacks reference to https
netstat plunt looks OK listening on 0.0.0.0 for 80 and 443
sudo iptables -nL looks OK
sudo ufw status 80 and 443 open seems fine
curl -vIL http://uroflowcanada.ddns.net
The /var/log/apache2/error.log
[Wed Nov 20 20:33:32.019390 2019] [core:trace4] [pid 520:tid 3069939424] mpm_common.c(536): mpm child 522 (gen 0/slot 0) exited
[Wed Nov 20 20:33:32.019887 2019] [core:trace4] [pid 520:tid 3069939424] mpm_common.c(536): mpm child 523 (gen 0/slot 1) exited
[Wed Nov 20 20:33:32.020197 2019] [core:info] [pid 520:tid 3069939424] AH00096: removed PID file /var/run/apache2/apache2.pid (pid=520)
[Wed Nov 20 20:33:32.020325 2019] [mpm_event:notice] [pid 520:tid 3069939424] AH00491: caught SIGTERM, shutting down
[Wed Nov 20 20:33:32.031613 2019] [core:trace4] [pid 520] mpm_common.c(431): end of generation 0
[Wed Nov 20 20:34:21.247997 2019] [ssl:trace2] [pid 912:tid 3069607648] ssl_engine_rand.c(126): Init: Seeding PRNG with 648 bytes of entropy
[Wed Nov 20 20:34:21.248357 2019] [ssl:info] [pid 912:tid 3069607648] AH01887: Init: Initializing (virtual) servers for SSL
[Wed Nov 20 20:34:21.248468 2019] [ssl:info] [pid 912:tid 3069607648] AH01914: Configuring server uroflowcanada.ddns.net:443 for SSL protocol
[Wed Nov 20 20:34:21.248564 2019] [ssl:debug] [pid 912:tid 3069607648] ssl_engine_init.c(1750): AH10083: Init: (uroflowcanada.ddns.net:443) mod_md support is unavailable.
[Wed Nov 20 20:34:21.248657 2019] [ssl:trace3] [pid 912:tid 3069607648] ssl_engine_init.c(579): Creating new SSL context (protocols: TLSv1, TLSv1.1, TLSv1.2, TLSv1.3)
[Wed Nov 20 20:34:21.250621 2019] [ssl:trace1] [pid 912:tid 3069607648] ssl_engine_init.c(915): Configuring permitted SSL ciphers [ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDS....
SHA:AES256-SHA:DES-CBC3-SHA:!DSS:!aNULL:!eNULL:!EXP]
[Wed Nov 20 20:34:21.251587 2019] [ssl:debug] [pid 912:tid 3069607648] ssl_engine_init.c(479): AH01893: Configuring TLS extension handling
[Wed Nov 20 20:34:21.255761 2019] [ssl:trace3] [pid 912:tid 3069607648] ssl_util_ssl.c(465): [uroflowcanada.ddns.net:443] modssl_X509_match_name: expecting name 'uroflowcanada.ddns.net', matched by ID 'uroflowcanada.ddns.net'
[Wed Nov 20 20:34:21.256543 2019] [ssl:debug] [pid 912:tid 3069607648] ssl_util_ssl.c(476): AH02412: [uroflowcanada.ddns.net:443] Cert matches for name 'uroflowcanada.ddns.net' [subject: CN=uroflowcanada.ddns.net / issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US / serial: 048BC71E036F4B99D4D55E5A925999149796 / notbefore: Nov 12 17:52:07 2019 GMT / notafter: Feb 10 17:52:07 2020 GMT]
[Wed Nov 20 20:34:21.256691 2019] [ssl:info] [pid 912:tid 3069607648] AH02568: Certificate and private key uroflowcanada.ddns.net:443:0 configured from /etc/letsencrypt/live/uroflowcanada.ddns.net/fullchain.pem and /etc/letsencrypt/live/uroflowcanada.ddns.net/privkey.pem
[Wed Nov 20 20:34:21.258328 2019] [ssl:info] [pid 912:tid 3069607648] AH01876: mod_ssl/2.4.38 compiled against Server: Apache/2.4.38, Library: OpenSSL/1.1.1d
[Wed Nov 20 20:34:21.344196 2019] [ssl:trace2] [pid 913:tid 3069607648] ssl_engine_rand.c(126): Init: Seeding PRNG with 648 bytes of entropy
[Wed Nov 20 20:34:21.386031 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(401): AH00821: shmcb_init allocated 512000 bytes of shared memory
[Wed Nov 20 20:34:21.386246 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(417): AH00822: for 511944 bytes (512000 including header), recommending 32 subcaches, 88 indexes each
[Wed Nov 20 20:34:21.386344 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(450): AH00824: shmcb_init_memory choices follow
[Wed Nov 20 20:34:21.386429 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(452): AH00825: subcache_num = 32
[Wed Nov 20 20:34:21.386860 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(454): AH00826: subcache_size = 15992
[Wed Nov 20 20:34:21.386963 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(456): AH00827: subcache_data_offset = 2128
[Wed Nov 20 20:34:21.387040 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(458): AH00828: subcache_data_size = 13864
[Wed Nov 20 20:34:21.387113 2019] [socache_shmcb:debug] [pid 913:tid 3069607648] mod_socache_shmcb.c(460): AH00829: index_num = 88
[Wed Nov 20 20:34:21.387738 2019] [socache_shmcb:info] [pid 913:tid 3069607648] AH00830: Shared memory socache initialised
[Wed Nov 20 20:34:21.387844 2019] [ssl:info] [pid 913:tid 3069607648] AH01887: Init: Initializing (virtual) servers for SSL
[Wed Nov 20 20:34:21.387929 2019] [ssl:info] [pid 913:tid 3069607648] AH01914: Configuring server uroflowcanada.ddns.net:443 for SSL protocol
[Wed Nov 20 20:34:21.388011 2019] [ssl:debug] [pid 913:tid 3069607648] ssl_engine_init.c(1750): AH10083: Init: (uroflowcanada.ddns.net:443) mod_md support is unavailable.
[Wed Nov 20 20:34:21.388098 2019] [ssl:trace3] [pid 913:tid 3069607648] ssl_engine_init.c(579): Creating new SSL context (protocols: TLSv1, TLSv1.1, TLSv1.2, TLSv1.3)
[Wed Nov 20 20:34:21.390339 2019] [ssl:trace1] [pid 913:tid 3069607648] ssl_engine_init.c(915): Configuring permitted SSL ciphers [ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS:!aNULL:!eNULL:!EXP]
[Wed Nov 20 20:34:21.391309 2019] [ssl:debug] [pid 913:tid 3069607648] ssl_engine_init.c(479): AH01893: Configuring TLS extension handling
[Wed Nov 20 20:34:21.401183 2019] [ssl:trace3] [pid 913:tid 3069607648] ssl_util_ssl.c(465): [uroflowcanada.ddns.net:443] modssl_X509_match_name: expecting name 'uroflowcanada.ddns.net', matched by ID 'uroflowcanada.ddns.net'
[Wed Nov 20 20:34:21.401753 2019] [ssl:debug] [pid 913:tid 3069607648] ssl_util_ssl.c(476): AH02412: [uroflowcanada.ddns.net:443] Cert matches for name 'uroflowcanada.ddns.net' [subject: CN=uroflowcanada.ddns.net / issuer: CN=Let's Encrypt Authority X3,O=Let's Encrypt,C=US / serial: 048BC71E036F4B99D4D55E5A925999149796 / notbefore: Nov 12 17:52:07 2019 GMT / notafter: Feb 10 17:52:07 2020 GMT]
[Wed Nov 20 20:34:21.401881 2019] [ssl:info] [pid 913:tid 3069607648] AH02568: Certificate and private key uroflowcanada.ddns.net:443:0 configured from /etc/letsencrypt/live/uroflowcanada.ddns.net/fullchain.pem and /etc/letsencrypt/live/uroflowcanada.ddns.net/privkey.pem
[Wed Nov 20 20:34:21.403588 2019] [ssl:info] [pid 913:tid 3069607648] AH01876: mod_ssl/2.4.38 compiled against Server: Apache/2.4.38, Library: OpenSSL/1.1.1d
[Wed Nov 20 20:34:21.404047 2019] [watchdog:debug] [pid 913:tid 3069607648] mod_watchdog.c(454): AH010033: Watchdog: Running with WatchdogInterval 1000ms
[Wed Nov 20 20:34:21.404174 2019] [watchdog:debug] [pid 913:tid 3069607648] mod_watchdog.c(462): AH02974: Watchdog: found parent providers.
[Wed Nov 20 20:34:21.404264 2019] [watchdog:debug] [pid 913:tid 3069607648] mod_watchdog.c(508): AH02977: Watchdog: found child providers.
[Wed Nov 20 20:34:21.404344 2019] [watchdog:debug] [pid 913:tid 3069607648] mod_watchdog.c(516): AH02978: Watchdog: Looking for child (singleton).
[Wed Nov 20 20:34:21.404487 2019] [watchdog:debug] [pid 913:tid 3069607648] mod_watchdog.c(516): AH02978: Watchdog: Looking for child (default).
[Wed Nov 20 20:34:21.418527 2019] [core:trace4] [pid 913:tid 3069607648] mpm_common.c(536): mpm child 915 (gen 0/slot 0) started
[Wed Nov 20 20:34:21.420831 2019] [core:trace4] [pid 913:tid 3069607648] mpm_common.c(536): mpm child 916 (gen 0/slot 1) started
[Wed Nov 20 20:34:21.421119 2019] [mpm_event:notice] [pid 913:tid 3069607648] AH00489: Apache/2.4.38 (Raspbian) OpenSSL/1.1.1d configured -- resuming normal operations
[Wed Nov 20 20:34:21.421222 2019] [mpm_event:info] [pid 913:tid 3069607648] AH00490: Server built: 2019-10-15T19:53:42
[Wed Nov 20 20:34:21.421391 2019] [core:notice] [pid 913:tid 3069607648] AH00094: Command line: '/usr/sbin/apache2'
[Wed Nov 20 20:34:21.421492 2019] [core:debug] [pid 913:tid 3069607648] log.c(1571): AH02639: Using SO_REUSEPORT: yes (1)
[Wed Nov 20 20:34:21.425685 2019] [watchdog:debug] [pid 915:tid 3069607648] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Wed Nov 20 20:34:21.431304 2019] [watchdog:debug] [pid 916:tid 3069607648] mod_watchdog.c(567): AH02980: Watchdog: nothing configured?
[Wed Nov 20 20:34:21.438779 2019] [mpm_event:debug] [pid 915:tid 3059082272] event.c(2314): AH02471: start_threads: Using epoll (wakeable)
[Wed Nov 20 20:34:21.456008 2019] [mpm_event:debug] [pid 916:tid 3059082272] event.c(2314): AH02471: start_threads: Using epoll (wakeable)
root@raspberrypi:/home/urouser#
Note no mention of the http://uroflowcanada.ddns.net that worked properly ??
root@raspberrypi:/home/urouser# sudo apache2ctl -S
[Wed Nov 20 20:47:13.177792 2019] [core:trace3] [pid 1038:tid 3069599456] core.c(3355): Setting LogLevel for all modules to trace8
*:80 uroflowcanada.ddns.net (/etc/apache2/sites-enabled/uroflowcanada.ddns.net.conf:1)
*:443 uroflowcanada.ddns.net (/etc/apache2/sites-enabled/uroflowcanada.ddns.net.conf:9)
Define: DUMP_VHOSTS
root@raspberrypi:/home/urouser# ls -l /etc/apache2/sites-available
total 16
-rw-r--r-- 1 root root 1332 Apr 2 2019 000-default.conf
-rw-r--r-- 1 root root 6338 Apr 2 2019 default-ssl.conf
-rw-r--r-- 1 root root 980 Nov 19 16:28 uroflowcanada.ddns.net.conf
root@raspberrypi:/home/urouser# sudo cat /etc/apache2/sites-available/uroflowcanada.ddns.net.conf
<VirtualHost *:80>
ServerAdmin jbrohan@gmail.com
ServerAlias www.uroflowcanada.ddns.net
DocumentRoot /var/www/uroflowcanada.ddns.net
<VirtualHost *:443>
#ServerName dev.example.com
SSLEngine on
#SSLCertificateFile "C:/prod/hosts.crt.pem"
#SSLCertificateKeyFile "C:/prod/hosts.key.pem"
#SSLCertificateChainFile "C:/prod/intermediate.crt.pem"
#Include conf/sites/dev.example.com.conf
root@raspberrypi:/home/urouser# ls -l /etc/apache2/sites-enabled
total 0
lrwxrwxrwx 1 root root 46 Nov 18 17:46 uroflowcanada.ddns.net.conf -> ../sites-available/uroflowcanada.ddns.net.conf
dig output
root@raspberrypi:/home/urouser# dig uroflowcanada.ddns.net
; <<>> DiG 9.11.5-P4-5.1-Raspbian <<>> uroflowcanada.ddns.net
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 52613
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;uroflowcanada.ddns.net. IN A
;; ANSWER SECTION:
uroflowcanada.ddns.net. 59 IN A 74.59.228.16
;; Query time: 31 msec
;; SERVER: 192.168.86.1#53(192.168.86.1)
;; WHEN: Wed Nov 20 21:11:08 GMT 2019
;; MSG SIZE rcvd: 67
74.59.228.16
nmap printout is voluminous and lacks reference to https.
Starting Nmap 7.70 ( https://nmap.org ) at 2019-11-20 21:16 GMT
WARNING: Service 74.59.228.16:5000 had already soft-matched upnp, but now soft-matched rtsp; ignoring second value
WARNING: Service 74.59.228.16:5000 had already soft-matched upnp, but now soft-matched sip; ignoring second value
Host is up (0.0095s latency).
Not shown: 995 closed ports
|http-title: Welcome to uroflowcanada.ddns.net!
81/tcp filtered hosts2-ns
5000/tcp open upnp MiniUPnP 1.9 (UPnP 1.1)
| FourOhFourRequest, GetRequest:
| HTTP/1.0 404 Not Found
| Content-Type: text/html
| Connection: close
| Content-Length: 134
| Server: chromiumos/rolling UPnP/1.1 MiniUPnPd/1.9
| Ext:
| 404 Not Found
Not Found
The requested URL was not found on this server.
| GenericLines:
| 501 Not Implemented
| Connection: close
| Content-Length: 149
| Ext:
| 501 Not Implemented
Not Implemented
The HTTP Method is not implemented by this server.
| HTTPOptions:
| HTTP/1.0 501 Not Implemented
| Connection: close
| Content-Length: 149
| Ext:
| 501 Not Implemented
Not Implemented
| RTSPRequest:
| RTSP/1.0 501 Not Implemented
| Connection: close
| Content-Length: 149
| Ext:
| 501 Not Implemented
Not Implemented
| SIPOptions:
| SIP/2.0 501 Not Implemented
| Connection: close
| Content-Length: 149
| Ext:
501 Not Implemented
Not Implemented
8080/tcp filtered http-proxy
8081/tcp open blackice-icecap?
| FourOhFourRequest:
| Content-Length: 9
| Content-Type: text/plain
| Date: Wed, 20 Nov 2019 21:17:33 GMT
| Found
| GetRequest:
| HTTP/1.0 200 OK
| Content-Length: 1067
| Google Wifi
This site was blocked.
<p class="status-desc
| HTTPOptions:
| Content-Length: 9
| Date: Wed, 20 Nov 2019 21:17:38 GMT
| Found
| RTSPRequest:
| HTTP/1.1 404 Not Found
| Content-Length: 9
| Found
| SIPOptions:
| Content-Length: 9
Found
2 services unrecognized despite returning data. If you know the service/version, please submit the following fingerprints at Nmap Fingerprint Submitter 2.0 :
==============NEXT SERVICE FINGERPRINT (SUBMIT INDIVIDUALLY)==============
SF-Port5000-TCP:V=7.70%I=7%D=11/20%Time=5DD5AD6D%P=arm-unknown-linux-gnuea
SF:20404\x20Not\x20Found\r\nContent-Length:\x209\r\nContent-Type:\x20text/
SF:plain\r\nDate:\x20Wed,\x2020\x20Nov\x202019\x2021:17:38\x20GMT\r\n\r\nN
SF:ot\x20Found");
Device type: general purpose
Running: Linux 3.X|4.X
OS CPE: cpe:/o:linux:linux_kernel:3 cpe:/o:linux:linux_kernel:4
OS details: Linux 3.2 - 4.9
Network Distance: 1 hop
TRACEROUTE (using port 23/tcp)
HOP RTT ADDRESS
1 17.19 ms modemcable016.228-59-74.mc.videotron.ca (74.59.228.16)
OS and Service detection performed. Please report any incorrect results at Nmap OS/Service Fingerprint and Correction Submission Page .
Nmap done: 1 IP address (1 host up) scanned in 126.60 seconds
Netstat plunt
netstat -plunt | egrep '80'
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 913/apache2
root@raspberrypi:/home/urouser# sudo netstat -plunt | egrep '443'
tcp 0 0 0.0.0.0:443 0.0.0.0:* LISTEN 913/apache2
sudo iptables -nL
Chain INPUT (policy DROP)
target prot opt source destination
ufw-before-logging-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-before-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-reject-input all -- 0.0.0.0/0 0.0.0.0/0
ufw-track-input all -- 0.0.0.0/0 0.0.0.0/0
Chain FORWARD (policy DROP)
ufw-before-logging-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-before-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-reject-forward all -- 0.0.0.0/0 0.0.0.0/0
ufw-track-forward all -- 0.0.0.0/0 0.0.0.0/0
Chain OUTPUT (policy ACCEPT)
ufw-before-logging-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-before-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-after-logging-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-reject-output all -- 0.0.0.0/0 0.0.0.0/0
ufw-track-output all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-logging-input (1 references)
Chain ufw-before-logging-output (1 references)
Chain ufw-before-logging-forward (1 references)
Chain ufw-before-input (1 references)
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT all -- 0.0.0.0/0 0.0.0.0/0 ctstate RELATED,ESTABLISHED
ufw-logging-deny all -- 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
DROP all -- 0.0.0.0/0 0.0.0.0/0 ctstate INVALID
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 3
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 11
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 12
ACCEPT icmp -- 0.0.0.0/0 0.0.0.0/0 icmptype 8
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp spt:67 dpt:68
ufw-not-local all -- 0.0.0.0/0 0.0.0.0/0
ACCEPT udp -- 0.0.0.0/0 224.0.0.251 udp dpt:5353
ACCEPT udp -- 0.0.0.0/0 239.255.255.250 udp dpt:1900
ufw-user-input all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-output (1 references)
ufw-user-output all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-before-forward (1 references)
ufw-user-forward all -- 0.0.0.0/0 0.0.0.0/0
Chain ufw-after-input (1 references)
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:137
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:138
ufw-skip-to-policy-input tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:139
ufw-skip-to-policy-input tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:445
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:67
ufw-skip-to-policy-input udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:68
ufw-skip-to-policy-input all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
Chain ufw-after-output (1 references)
Chain ufw-after-forward (1 references)
Chain ufw-after-logging-input (1 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10 LOG flags 0 level 4 prefix "[UFW BLOCK] "
Chain ufw-after-logging-output (1 references)
Chain ufw-after-logging-forward (1 references)
Chain ufw-reject-input (1 references)
Chain ufw-reject-output (1 references)
Chain ufw-reject-forward (1 references)
Chain ufw-track-input (1 references)
Chain ufw-track-output (1 references)
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 ctstate NEW
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 ctstate NEW
Chain ufw-track-forward (1 references)
Chain ufw-logging-deny (2 references)
Chain ufw-not-local (1 references)
RETURN all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type LOCAL
RETURN all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type MULTICAST
RETURN all -- 0.0.0.0/0 0.0.0.0/0 ADDRTYPE match dst-type BROADCAST
ufw-logging-deny all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 10
Chain ufw-user-input (1 references)
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:22
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:22
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:80
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:443
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 multiport dports 80,443 /* 'dapp_WWW%20Full' */
Chain ufw-user-output (1 references)
Chain ufw-user-forward (1 references)
Chain ufw-user-logging-input (0 references)
Chain ufw-user-logging-output (0 references)
Chain ufw-user-logging-forward (0 references)
Chain ufw-user-limit (0 references)
LOG all -- 0.0.0.0/0 0.0.0.0/0 limit: avg 3/min burst 5 LOG flags 0 level 4 prefix "[UFW LIMIT BLOCK] "
REJECT all -- 0.0.0.0/0 0.0.0.0/0 reject-with icmp-port-unreachable
Chain ufw-user-limit-accept (0 references)
sudo ufw status
Status: active
To Action From
22 ALLOW Anywhere
80/tcp ALLOW Anywhere
443/tcp ALLOW Anywhere
WWW Full ALLOW Anywhere
22 (v6) ALLOW Anywhere (v6)
80/tcp (v6) ALLOW Anywhere (v6)
443/tcp (v6) ALLOW Anywhere (v6)
WWW Full (v6) ALLOW Anywhere (v6)
  • Expire in 0 ms for 6 (transfer 0x604880)
  • Expire in 50 ms for 1 (transfer 0x604880)
  • Trying 74.59.228.16...
  • TCP_NODELAY set
  • Expire in 200 ms for 4 (transfer 0x604880)
  • Connected to uroflowcanada.ddns.net (74.59.228.16) port 80 (#0)
HEAD / HTTP/1.1
Host: uroflowcanada.ddns.net
User-Agent: curl/7.64.0
Accept: /
< HTTP/1.1 200 OK
HTTP/1.1 200 OK
< Date: Wed, 20 Nov 2019 21:39:25 GMT
< Server: Apache/2.4.38 (Raspbian)
< Last-Modified: Mon, 18 Nov 2019 17:44:27 GMT
< ETag: "c6-597a27fc0a42c"
< Accept-Ranges: bytes
< Content-Length: 198
Content-Length: 198
  • Connection #0 to host uroflowcanada.ddns.net left intact
    root@raspberrypi:/home/urouser# curl -vIL https://uroflowcanada.ddns.net
  • Expire in 0 ms for 6 (transfer 0x37b880)
  • Expire in 50 ms for 1 (transfer 0x37b880)
  • TCP_NODELAY set
  • Expire in 200 ms for 4 (transfer 0x37b880)
  • connect to 74.59.228.16 port 443 failed: Connection refused
  • Failed to connect to uroflowcanada.ddns.net port 443: Connection refused
  • Closing connection 0
    curl: (7) Failed to connect to uroflowcanada.ddns.net port 443: Connection refused
  • Expire in 0 ms for 6 (transfer 0x8ce880)
  • Trying ::1...
  • TCP_NODELAY set
  • Expire in 149990 ms for 3 (transfer 0x8ce880)
  • Expire in 200 ms for 4 (transfer 0x8ce880)
  • connect to ::1 port 443 failed: Connection refused
  • Trying 127.0.0.1...
  • TCP_NODELAY set
  • Expire in 149984 ms for 3 (transfer 0x8ce880)
  • Connected to localhost (127.0.0.1) port 443 (#0)
  • ALPN, offering h2
  • ALPN, offering http/1.1
  • successfully set certificate verify locations:
  • CAfile: none
    CApath: /etc/ssl/certs
  • TLSv1.3 (OUT), TLS handshake, Client hello (1):
  • TLSv1.3 (IN), TLS handshake, Server hello (2):
  • TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
  • TLSv1.3 (IN), TLS handshake, Certificate (11):
  • TLSv1.3 (IN), TLS handshake, CERT verify (15):
  • TLSv1.3 (IN), TLS handshake, Finished (20):
  • TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
  • TLSv1.3 (OUT), TLS handshake, Finished (20):
  • SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
  • ALPN, server accepted to use http/1.1
  • Server certificate:
  • subject: CN=uroflowcanada.ddns.net
  • start date: Nov 12 17:52:07 2019 GMT
  • expire date: Feb 10 17:52:07 2020 GMT
  • subjectAltName does not match localhost
  • SSL: no alternative certificate subject name matches target host name 'localhost'
    curl: (60) SSL: no alternative certificate subject name matches target host name 'localhost'
    More details here: curl - SSL CA Certificates
curl failed to verify the legitimacy of the server and therefore could not
establish a secure connection to it. To learn more about this situation and
how to fix it, please visit the web page mentioned above.
@jbrohan,
Apologies for the long delay in getting back to you.
Your internal curl call looks fine which means that your TLS vhost is configured correctly. curl -vIL https://localhost
Do you run a firewall on your network besides the raspberry pi firewall? Perhaps one that’s built into your router? If so, check if you can open TCP/443. At this point I think it’s just a simple networking issue.
