QUIC.cloud problems with Android <7.1
I am using QUIC.cloud for connecting LSCache to them for DNS, SSL and CDN. The certificate chain they installed causes browser requests from Edge or Chrome browsers on Android less than 7.1 to cause a "not trusted" error. I understand that LetsEncrypt has a solution for this and was wondering how I could get the proper chain from you so I could install it manually through QUIC.cloud (they make provision for third party certificates). I realize QUIC.cloud uses LetsEncrypt, but for some reason their deployment doesn't work so I thought if you could supply me with a working certificate, I could install it manually through their manual entry process. They can manually install the certificate and private key.
My domain is: clearvoiceu.net
I ran this command: clearvoiceu.net on an Android phone < 7.1
It produced this output: On Edge and Chrome, certificate was not trusted
My web server is (include version): OpenLiteSpeed
The operating system my web server runs on is (include version): Ubuntu 20.04.4 LTS
My hosting provider, if applicable, is: RunCloud connected to Digital Ocean
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): using QUIC.cloud for DNS, SSL & CDN
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): N/A
Your website is using the "short chain" instead of the default one. This is expected.
$ openssl s_client -connect clearvoiceu.net:443
CONNECTED(00000003)
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = clearvoiceu.net
verify return:1
Certificate chain
 0 s:CN = clearvoiceu.net
   a:PKEY: id-ecPublicKey, 384 (bit); sigalg: RSA-SHA256
   v:NotBefore: Apr 26 16:31:36 2022 GMT; NotAfter: Jul 25 16:31:35 2022 GMT
   a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA256
   v:NotBefore: Sep  4 00:00:00 2020 GMT; NotAfter: Sep 15 16:00:00 2025 GMT
How can I get it to use the long chain so Android <7.1 will be OK?
I don't know QUIC.cloud, so I don't know if you can do it by yourself or you have to ask them.
They make provision to manually install your own certificate, so I was wondering if I could get a long chain certificate and install it using QUIC.cloud's manual process?
Probably, but you'd have to repeat the process every two months.
I think you should complain.
How would I go about asking LetsEncrypt for a long chain certificate without using certbot?
If you are using certbot already, the certificate you have is probably using the long chain already.
If you don't like certbot you can use another acme client, but there's no human interface to ask for certificates, like a paid CA.
Are all the certificates stored in the same place? I can see server.crt and server.key. There are two certificates in server.crt and one in server.key. In other words, would the hosting provider store a certificate in one place and the CDN store one in another place. If so, I can install certbot and have it install the long chain certificates.
Certbot doesn't use those filenames, so I don't know.
The certificate and key can be the same, and the only difference be the chain.
It depends on how much control you have over the system.
If none, ask the provider for assistance.
If root, then you can control the ACME client and switch chains OR even to another ACME CA.
If somewhere in between, it really depends on the access you have to the location of the cert files, the amount of scripting that can be done and your willingness to roll your sleeves up and create your own solution.
OR
You might be able to put the site behind Cloudflare CDN and be done with it.
[note: I'm not 100% certain Cloudflare supports QUIC - but it's 2022 and they should]
