Let’s Encrypt renewal issues with Android-focused script tool domain
I’m having trouble with certificate renewal for a small Android tools site (used by script-based utilities like arceusX tools). The site runs on Nginx and uses Certbot for Let’s Encrypt integration.
The first certificate installed fine, but autorenewal fails due to DNS resolution issues. Logs show a timeout during challenge validation — possibly due to nonstandard user agent access or firewall rules.
Anyone else faced similar problems with smaller or app-specific domains? Would switching from HTTP-01 to DNS-01 help in this case?
Appreciate any tips — thanks in advance!
you aren't using Let's Encrypt certificate at all, but Google Trust Service Certificate from May 7th. (cloudflare requested) do you actually need own certificate here? as It's cloudflare managed you can use Cloudflare origin CA
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it (and make our life a lot harder). In any case, all the answers to this questionnaire are required:
Also, I've removed the hyperlink to that "arceusX tools" website. From your wording it was just "some example" and not the site you're having issues with and as it was it looked very much like spam.
