Python Process Takes Port 443
Hello
I often happen these days that the server crashes at different times.
The Apache error is:
(98) Address already in use: make_sock: could not bind to address [::]: 443
If I analyze the server with the command:
netstat -anp | grep: 443
I find out that python has a process on 443.
How do I solve the problem?
The operating system my web server runs on is (include version): Ubuntu Server 14
I’m not sure this forum is the best place to look for an answer to such a problem.
Hello
Ok but…the problem is born after installing certbot and its dependencies to generate certificates.
Before there have never been problems
Could you provide more info on how you ran Certbot initially? I’m guessing it was in standalone mode, which will run a temporary webserver that might take up port 443. If you have a webserver running, this usually isn’t how you want to go about things. However, usually Certbot is the one that has the issue starting rather than Apache.
