I'm trying to configure letsencrypt to run on my server, which is an Ubuntu 14.04 running on a VM on Azure, using Node.js and Express.
I've cloned letsencrypt from the repository, and I'm trying to generate a certificate for my domain using the following command:
sudo ./letsencrypt-auto certonly -d my_domain_here --server https://acme-v01.api.letsencrypt.org/directory --renew-by-default --agree-tos
I have already tried several combinations of commands, always ending up with the same error.
when I try to run it from the command-line using the letsencrypt-auto tool, I get the following error:
2016-01-22 07:10:37,823:DEBUG:letsencrypt.cli:Root logging level set at 30
2016-01-22 07:10:37,823:INFO:letsencrypt.cli:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2016-01-22 07:10:37,823:DEBUG:letsencrypt.cli:letsencrypt version: 0.2.0
2016-01-22 07:10:37,823:DEBUG:letsencrypt.cli:Arguments: ['-d', 'domain', '--server', 'https://acme-v01.api.letsencrypt.org/directory', '--renew-by-default', '--agree-tos']
2016-01-22 07:10:37,823:DEBUG:letsencrypt.cli:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntryPoint#webroot,PluginEntryPoint#null,PluginEntryPoint#manual,PluginEntryPoint#standalone)
2016-01-22 07:10:37,832:DEBUG:letsencrypt.cli:Requested authenticator None and installer None
2016-01-22 07:10:38,030:DEBUG:letsencrypt.plugins.disco:No installation (PluginEntryPoint#apache):
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/plugins/disco.py", line 103, in prepare
self._initialized.prepare()
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt_apache/configurator.py", line 149, in prepare
raise errors.NoInstallationError
NoInstallationError
2016-01-22 07:10:38,031:DEBUG:letsencrypt.plugins.disco:Other error:(PluginEntryPoint#webroot): --webroot-path must be set
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/plugins/webroot.py", line 53, in prepare
self.option_name("path")))
PluginError: --webroot-path must be set
2016-01-22 07:10:38,032:DEBUG:letsencrypt.display.ops:Single candidate plugin: * standalone
Description: Automatically use a temporary webserver
Entry point: standalone = letsencrypt.plugins.standalone:Authenticator
Initialized: <letsencrypt.plugins.standalone.Authenticator object at 0x7f0a73f54b10>
Prep: True
2016-01-22 07:10:38,032:DEBUG:letsencrypt.cli:Selected authenticator <letsencrypt.plugins.standalone.Authenticator object at 0x7f0a73f54b10> and installer None
2016-01-22 07:10:38,033:DEBUG:letsencrypt.cli:Exiting abnormally:
File "/home/guilherme/.local/share/letsencrypt/bin/letsencrypt", line 11, in
sys.exit(main())
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py", line 1398, in main
return args.func(args, config, plugins)
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py", line 589, in obtain_cert
le_client = _init_le_client(args, config, authenticator, installer)
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py", line 176, in _init_le_client
acc, acme = _determine_account(args, config)
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/cli.py", line 142, in _determine_account
accounts = account_storage.find_all()
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/account.py", line 160, in find_all
accounts.append(self.load(account_id))
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/letsencrypt/account.py", line 173, in load
regr = messages.RegistrationResource.json_loads(regr_file.read())
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/acme/jose/interfaces.py", line 180, in json_loads
return cls.from_json(loads)
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/acme/jose/json_util.py", line 297, in from_json
return cls(**cls.fields_from_json(jobj))
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/acme/jose/json_util.py", line 280, in fields_from_json
cls._check_required(jobj)
File "/home/guilherme/.local/share/letsencrypt/local/lib/python2.7/site-packages/acme/jose/json_util.py", line 275, in _check_required
','.join(missing)))
DeserializationError: Deserialization error: The following field are required: uri,new_authzr_uri
How can I solve this? Why is that happening?
