Error: Command failed: certbot certonly --config "/etc/letsencrypt.ini" --work-dir "/tmp/letsencrypt-lib" --logs-dir "/tmp/letsencrypt-log" --cert-name "npm-13" --agree-tos --authenticator webroot --email "lasse@lasse.us" --preferred-challenges "dns,http" --domains "test.lasse.us"
Saving debug log to /tmp/letsencrypt-log/letsencrypt.log
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/letsencrypt-log/letsencrypt.log or re-run Certbot with -v for more details.
at ChildProcess.exithandler (node:child_process:402:12)
at ChildProcess.emit (node:events:513:28)
at maybeClose (node:internal/child_process:1100:16)
at Process.ChildProcess._handle.onexit (node:internal/child_process:304:5)
After swapping out Pfsense to UXG I got really big problems. None of my proxys work. And when I try to make a new SSL Certificate I get this error. I try both the Nginx proxy manager addon for Home assistant and even Nginx proxy manager in LCX container in Proxmox.... This is so frustrating. Both 80 and 443 are open to both HA ip and Nginx proxy manager LCX. Any tips???
