Problems w/ completing process while installing on Amazon Lightsail
My domain is: http://www.evansinvestigations.com
I ran this command:./certbot-auto certonly --webroot -w /home/bitnami/apps/wordpress/htdocs/ -d wordpresstutorialsadvanced.in -d www.wordpresstutorialsadvanced.in
My web server is (include version):not sure
The operating system my web server runs on is (include version):not sure
My hosting provider, if applicable, is:Amazon
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
I think you need to check on your DNS. That domain doesn’t seem to resolve to anything.
>nslookup
Default Server:  UnKnown
Address:  2605:a601:5210:37::1
Server:  UnKnown
*** No internal type for both IPv4 and IPv6 Addresses (A+AAAA) records available for evansinvestigations.com
> server 8.8.8.8
Default Server:  google-public-dns-a.google.com
Address:  8.8.8.8
Address:  8.8.8.8
Thank you for your reply.
I did see on one of the command lines regarding the error to check the DNS. I’m guessing they are referring to the Nameservers?
I have confirmed that I have an ‘A’ Record, which is www.evansinvestigations.com. After that I checked to make sure that the Nameservers that Amazon Lightsail provided are exactly what is in place where I manage my domain name at. FYI it is registered at GoDaddy.
There is. But there isn't an A record for evansinvestigations.com.. It's separate, and you need to add one.
Thank you for pointing that out. After adding the additional A Record everything else went pretty smooth.
