Problems adding a domain to existing certificate
1: app4backpackers.com
2: app4pickup.com
3: catandbarz.com
4: app4backpackers.com.au
5: catandbarz.com.au
6: fensoment.com.au
7: fensomsoftware.com.au
8: gigabout.com.au
9: fensoment.com
10: fensomsoftware.com
11: mail.fensomsoftware.com
sudo certbot -d app4backpackers.com -d app4pickup.com -d catandbarz.com -d app4backpackers.com.au -d catandbarz.com.au -d fensoment.com.au -d fensomsoftware.com.au -d fensoment.com -d fensomsoftware.com -d gigabout.com.au
How would you like to authenticate and install certificates?
1: Apache Web Server plugin (apache)
2: Nginx Web Server plugin (nginx)
requested (ref: /etc/letsencrypt/renewal/app4pickup.com.conf)
It contains these names: catandbarz.com, app4pickup.com, fensoment.com,
fensomsoftware.com
You requested these names for the new certificate: app4backpackers.com,
app4pickup.com, catandbarz.com, app4backpackers.com.au, catandbarz.com.au,
fensoment.com.au, fensomsoftware.com.au, fensoment.com, fensomsoftware.com,
gigabout.com.au.
certificate?
(E)xpand/(C)ancel: E
Renewing an existing certificate for app4backpackers.com and 9 more domains
Domain: app4backpackers.com.au
Type: dns
Detail: DNS problem: SERVFAIL looking up A for app4backpackers.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for app4backpackers.com.au - the domain's nameservers may be malfunctioning
Domain: fensomsoftware.com.au
Type: dns
Detail: DNS problem: SERVFAIL looking up A for fensomsoftware.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for fensomsoftware.com.au - the domain's nameservers may be malfunctioning
Domain: fensoment.com.au
Type: dns
Detail: DNS problem: SERVFAIL looking up A for fensoment.com.au - the domain's nameservers may be malfunctioning; DNS problem: SERVFAIL looking up AAAA for fensoment.com.au - the domain's nameservers may be malfunctioning
Detail: 2404:9400:1:0:216:3eff:fef2:d5e6: Invalid response from http://app4backpackers.com/.well-known/acme-challenge/HHoYNcU0F5ouPG3jkQwl25CXNYvIbmU70Ikq8GiZTyw: 404
Domain: catandbarz.com
Detail: 2404:9400:1:0:216:3eff:fef2:d5e6: Invalid response from http://catandbarz.com/.well-known/acme-challenge/xTYYguEIfBknoGFz8IUdeT-Ciax8ZsWak2Of0hXD8wc: 404
Domain: catandbarz.com.au
Detail: 2404:9400:1:0:216:3eff:fef2:d5e6: Invalid response from http://catandbarz.com.au/.well-known/acme-challenge/xqGy7cHeAf8LqCUDypiG6QQVPHbQF1Ip6gqZXTCYrhQ: 404
Detail: 2404:9400:1:0:216:3eff:fef2:d5e6: Invalid response from http://fensomsoftware.com/.well-known/acme-challenge/geE2Ib2bVcRhGgI-kaSSB29wkPaDNx1YfO5hJ70H87w: 404
Domain: gigabout.com.au
Detail: 2404:9400:1:0:216:3eff:fef2:d5e6: Invalid response from http://gigabout.com.au/.well-known/acme-challenge/0hinnPGLXuh9PJR1ribTcL_YujxMxfV1veHQKmdqZ14: 404
nginx version: nginx/1.18.0 (Ubuntu)
Ubuntu 22.04.4 LTS
Release: 22.04
binarylane.com.au
Yes
No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
Your DNS seems to be severely broken, see fensomsoftware.com.au | DNSViz.
The nameservers that are configured as authorative nameservers seem to refuse to answer for your domain name. Are the authorative nameservers correctly configured?
I just disabled ip6 in my hosts control panel and the certificate is issued now. I will try to fix my dns issues.
