my problem is that all domains on my main server (about 80) can not update letsencrypt since about a month. I am using plesk as backand but it is not a plesk issue. The cert bot runs fine and all files (especially the verification files) are generated immediately. But I always get an
whenever I try to update letsencrypt.
The error message is always “Error getting validation data”, but the verification files are there and accessible. Tested from a bunch of different network adresses)
Apache with Nginx proxy
Ubuntu 16.04
My hosting provider, if applicable, is: hosteurope.de
plesk onyx
No clue as I need to use the plesk manager. As I stated the problem is in verification and probably the access from letsencrypt to my server.
The ipv6 I removed minutes ago, in a hunch that there might be a problem and I try again in 2Days. This new cert was created manualy to see if DNS auth works, so I could fallback to manual if possible
Which it does. The other problem still exists. Automatic authentication via http files does not work.
