Problem with update certbot for apache on ubuntu
Hey guys,
Regarding this topic: How to stop using TLS-SNI-01 with Certbot i want to update my certbot version from 0.23 to latest. I’ve tried to do the install routine again:
  • $ sudo apt-get update
  • $ sudo apt-get install software-properties-common
  • $ sudo add-apt-repository universe
  • $ sudo add-apt-repository ppa:certbot/certbot
  • $ sudo apt-get install python-certbot-apache
but after that i got the message: python-certbot-apache is already the newest version (0.28.0-1+ubuntu18.04.1+certbot+3) which sounds okay :slight_smile: but if i run certbot --version || /path/to/certbot-auto --version again it says certbot 0.23.0
Apache/2.4.29 (Ubuntu)
Ubuntu 18.04 LTS
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.23.0
Thank you guys!
Found a solution here: Version Upgrade
What i’ve done:
apt-get update & apt-cache policy certbot
sudo apt-get --with-new-pkgs upgrade because certbot kept back
and after that certbot --version || /path/to/certbot-auto --version says:
certbot 0.28.0
