Problem with Punycode Domains
Hi Community,
i have a Problem with a Punycode Domain, so i searched in this Community how to solve it. I seen i had a outdated version of certbot (certbot 0.8.1) and Punycode Domains should be supported after version 0.9.2, so i updated my version with yum update certbot, now i have the new version certbot 0.9.3, but still cant verify punycode domains.
My domain is: süsse-engel.com
Punycode is: süsse-engel.com
I ran this command: /usr/bin/certbot --non-interactive --expand certonly --webroot -w $documentroot -d www.süsse-engel.com,m.süsse-engel.com,ds.süsse-engel.com,süsse-engel.com
It produced this output: Punycode domains are not presently supported: www.süsse-engel.com
My operating system is (include version): CentOS Linux release 7.2.1511 (Core)
My web server is (include version): Apache/2.4.6 (CentOS)
My Version of Certbot is: certbot 0.9.3
Hi @Sm3rT,
If you're running 0.9.3, the error that should have been displayed is
Non-ASCII domain names not supported. To issue for an Internationalized Domain Name, use Punycode.
In this case, Certbot is asking you to explicitly request the Punycode form of your domain name. Version 0.9.3 should be willing to submit this request. If you're still getting the "Punycode domains are not presently supported" error, you're probably still unintentionally running 0.8.1 even if you also have 0.9.3 installed.
Hi @schoen,
i looked for my version of certbot and i only see the 0.9.3 version on my system.
rpm -qa | grep certbot
python2-certbot-0.9.3-1.el7.noarch
i run this command:
But still the same error:
@erica @bmw, wasn’t this restriction (and error message) already removed in 0.9.3? How could it be displaying this message?
No. Support for this landed in 0.10.0 (source).
Luckily, Certbot 0.12.0 is available in EPEL 7 on CentOS so if you upgrade your Certbot version this problem should go away.
@bmw @schoen
Thanks a lot, with new version (certbot-0.12.0-4) is all good :slight_smile:
  • Congratulations! Your certificate and chain have been saved at
    /etc/letsencrypt/live/www.xn–ssse-engel-9db.com/fullchain.pem.
greetz Sm3rT
