Problem with privkey.pem
My domain is: manotom.com
I ran this command: certbot certonly -d *.manotom.by --manual --preferred-challenges dns
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.4.0
everything was created fine, but by going to /etc/letsencrypt/archive/manotom.com-0001/
cert1.pem everything is fine
chain 1.pem everything is fine
full chain 1.pem is also fine
privkey.pem of a reduced size is very small.
and how to deal with it and where to dig.
Since version 2.0, Certbot defaults to ECDSA keys for certificates. They are smaller and faster than RSA keys and are recommended for all users.
If you need an RSA key for whatever reason, you can issue another certificate, adding --key-type rsa to your Certbot command.
