Starting from this morning I am getting OSCP stampling errors for multi sites located in different countries (only on FireFox)
SSL Labs reports:
Revocation status Validation error
OCSP ERROR: Exception: Read timed out [http://ocsp.int-x3.letsencrypt.org/]
Error in Apache:
[Fri May 19 09:19:35.456041 2017] [ssl:error] [pid 21754:tid 140012460939008] AH01941: stapling_renew_response: responder error
[Fri May 19 09:23:48.309237 2017] [ssl:error] [pid 22011:tid 139882496182016] (70007)The timeout specified has expired: [client 1.2.3.4:57240] AH01977: failed reading line from OCSP server
[Fri May 19 09:23:48.309280 2017] [ssl:error] [pid 22011:tid 139882496182016] [client 1.2.3.4:57240] AH01980: bad response from OCSP server: (none)
This error is a result of an ongoing service disruption. Please follow status.letsencrypt.org for more information. We should have all of the remaining issues resolved shortly.
In the meantime I’m going to lock this thread since there isn’t a need for further discussion on this particular error. Please open a new thread if you need to resume discussion.
Thanks for your patience, we apologize for the disruption and I expect more detailed root cause information will be shared in the near future.
Edit: The root cause of the issue above has long been resolved. Please open a new thread if you are experiencing OCSP trouble.
