Hello,
I’m using nextcloudpi hosted on a Raspberry pi at home. I am not an experienced user, so please, bear with me. My server was running smoothly until the certificate was not renewed, it was concomitant to a nextcloudpi update that did not succeed. The update problem is now fixed, but I can’t renew my certificate. I think it may be not related with the update anymore, as I had this same problem about 2 years ago which resolved by itself few months later. But it is quite annoying to have this issue and not knowing how to deal with it. I believe it’s related to IPv6, but I have zero knowledge on that.
My domain is: vercingeto.freeboxos.fr
I ran this command: Running letsencrypt from the TUI of nextcloupi leads to:
Running letsencrypt
http-01 challenge for vercingeto.freeboxos.fr
Using the webroot path /var/www/nextcloud for all unmatched domains.
Failed authorization procedure. vercingeto.freeboxos.fr (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://vercingeto.freeboxos.fr/.well-known/acme-challenge/kQGybT3-8Do6Lpz2ERf8MOz6MUfhGs7V79awHy7Bvhs: Timeout during connect (likely firewall problem)
Domain: vercingeto.freeboxos.fr
Type: connection
Detail: Fetching
Here is the letsdebug output: https://letsdebug.net/vercingeto.freeboxos.fr/30867
Here are the info of the server:
NextCloudPi version v1.10.7
NextCloudPi image NextCloudPi_10-05-18
distribution Raspbian GNU/Linux 9 \n \l
automount yes
USB devices sda
datadir /media/USBdrive/ncdata
data in SD no
data filesystem btrfs
data disk usage 730G/932G
rootfs usage 2.4G/15G
swapfile /var/swap
dbdir /var/lib/mysql
Nextcloud check ok
Nextcloud version 15.0.5.3
HTTPD service up
PHP service up
MariaDB service up
Redis service up
Postfix service up
internet check ok
port check 80 open
port check 443 open
interface eth0
certificates vercingeto.freeboxos.fr
NAT loopback yes
uptime 23:05
My hosting provider, if applicable, is: NA
no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0 (not sure if nextcloudpi is using the same)
What should I do ?
Thanks
