My web server is (include version): Server version: Apache/2.4.25 (Debian)
The operating system my web server runs on is (include version): Debian 9 Stretch
My hosting provider, if applicable, is: self hosted
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): bash shell
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.28.0
That can't work. You have to register a domain name, then create a DNS A entry yourdomain -> yourip, the ip address must be worldwide visible. So Letsencrypt can validate your domain ownership.
sudo certbot --apache -d other-40.umwelt-campus.de
or sudo certbot run -a webroot -i apache -w /var/www/html/collab/ -d other-40.umwelt-campus.de
Still gets me:
Failed authorization procedure. other-40.umwelt-campus.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://other-40.umwelt-campus.de/.well-known/acme-challenge/iK5FafFe9xPfSI4v47k1SaBi76FTYRAnN7SiqYsPmOg: Timeout during connect (likely firewall problem)
Domain: other-40.umwelt-campus.de
Type: connection
Detail: Fetching
